Old 05-29-2013, 12:19 PM   #1
rbizzle004
Battery Terminal for Amp Install
I was just wondering what aftermarket battery terminal are you guys using to install the amp to the postive terminal and how are you installing it?
I havent taken the factory terminal off to look underneath yet. Are you guys modifying by using a longer bolt and then attaching it to a nut? Or have you found a termianl that fits and stays secure on the postive post with out any modification.
Thanks Ryan
rbizzle004 is offline   Reply With Quote
Old 05-31-2013, 11:13 AM   #2
rbizzle004
Bump...anyone with a system installed?
Old 05-31-2013, 11:20 AM   #3
cruzinbill
Drives: Argento 6spd FR-S
I just took the nut off the side and put a ring terminal there.
cruzinbill is offline   Reply With Quote
Old 06-05-2013, 12:46 AM   #4
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
ya, i did the same....no need to get fancy and is easy to remove if needed
Kayzer Soze is offline   Reply With Quote
DIY: 5lb Shorai Battery Install industrial DIY (Do-It-Yourself) Guides 157 01-11-2024 10:49 AM
Bad battery 5hairpins Issues | Warranty | Recalls / TSB 3 02-25-2013 10:01 AM
Winter: Electric car & battery warmer install JSUB BRZ First-Gen (2012+) — General Topics 2 12-26-2012 10:55 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
