Old 06-17-2021, 03:56 PM   #1
Ali3583
Drives: Scion FRS 2013
My FRS 2013 Automatic Is Making Sounds When I Brake
as you can see in the YouTube video I am pressing on the brake without the hand brake pulled up. when I lift my foot off the brake it makes the first sound. When I release it quickly it makes the second sound. Can anyone help with this and tell me the problem?
Ali3583 is offline   Reply With Quote
The Following User Says Thank You to Ali3583 For This Useful Post:
humfrz (06-20-2021)
Old 06-20-2021, 10:17 PM   #2
humfrz
Hi ya, Ali3583 and welcome to our forum -
That is one weird sound, even coming from an FR-S.
I can't tell from your video, is your car moving when you make it make those sounds?
Where does it appear that the sound coming from?
Might I suggest a simple solution (which is usually wrong - ), that would be to check the brake fluid level.
Consider bleeding the brake fluid system?
Old 06-21-2021, 10:43 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Have someone else sit in the car and hit the brake while you look listen under the hood for where it is coming from. My guess is brake booster, or ABS pump making the noise. Does it stop normal when you hit the brake? Need a bit more info.
Old 06-21-2021, 06:40 PM   #4
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I know if the car sits the ebrake can get stuck. Especially if it’s been raining. I would check all the brakes and fluid.
Ernest72 is offline   Reply With Quote
automatic frs, brake, frs, help needed, problem
Manual BRZ sounds different than automatic one. BRZ_Prague BRZ First-Gen (2012+) — General Topics 18 02-25-2023 09:27 AM
Rear brake assembly smoking, making clacking noises. See video morswestford Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 04-24-2020 11:58 AM
Brake Squeak and sounds MatthewFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-28-2017 05:22 PM
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 05:33 PM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 02:24 PM
