Old 06-14-2021, 10:15 PM   #1
askho
Drives: 2013 Subaru BRZ
Verus / Velox camberplate alternate spring perch
Hello! I have a set of Verus camber plates that I want to use with Bilstein B16 coilovers with swapped 60mm springs. Since the OEM spring perch is not going to work, does anyone know if Raceseng spring perches / bushings will work with the verus camber plates? From my research I will need a 60mm spring perch and 15mm perch bushing.
Thanks in advance!
askho is offline   Reply With Quote
Old 06-15-2021, 01:13 PM   #2
marco_mc22
Drives: Toyota 86
Use kw hardware from v1 or v3
marco_mc22 is offline   Reply With Quote
Old 06-18-2021, 07:42 PM   #3
askho
So I went and ordered the Racseng spring perches + bushing anyways and it looks like they fit with one another. So if anyone else decides to use Verus camber plates with other spring sizes this is a way you can do that.
SOLD: Velox/Verus Cam Plate staro0989 Engine, Exhaust, Bolt-Ons 17 07-24-2020 07:47 PM
Strut spring perch clearance ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-12-2018 09:34 PM
Spring perch clearance check iyoiyo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-22-2017 10:45 PM
Vorshlag Upper Spring Perch Wusaa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-06-2016 02:36 AM
Clearance to spring perch Gearhead1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-07-2014 05:56 PM
