Old 07-22-2017, 04:49 PM   #1
iyoiyo
Drives: 2016 - FRS
Spring perch clearance check
need help ! will rub ? First time install wheels, and looks really tight. Stock suspension. Photo was while on jack
iyoiyo is offline   Reply With Quote
Old 07-22-2017, 05:01 PM   #2
mrg666
pessimistic skeptic
mrg666's Avatar
What are the wheel specs?
Old 07-22-2017, 05:16 PM   #3
iyoiyo
Drives: 2016 - FRS
it is 18 x 9.5 +43 with +5 mm wheel spacer
and tire 245/35 r18
Old 07-22-2017, 08:55 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
and tire 245/35 r18
It seems too close to me and I think you need lower offset or thicker wheel spacer to move the wheel out. If you cannot replace the wheels with +38 offset while using 5mm spacer, you could try 10mm spacer. But 9.5" is wide, is it poking outside already? The 10mm spacer will make it poke even more. I can see that the sidewall is stretched a little too much on your picture. For 245/35r18 tire, 8.5" is the recommended wheel width, although 9.5" width is borderline within the specs. If you can replace the wheel with 18x8 or 18x8.5 with +38-40 offset, I think you would have no problems and no spacers needed.
Old 07-22-2017, 10:45 PM   #5
iyoiyo
Drives: 2016 - FRS
Yes, it is poking out already. I have already mount my tires and have to go with this wheel. I think im gonna get my coilovers right away, and set the wheel on the side for now. Thanks man !
Raceseng CasCam - Caster + Camber Plates with Spring Perch RJasonKlein Brakes, Suspension, Chassis 3 01-26-2017 07:14 PM
Vorshlag Upper Spring Perch Wusaa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-06-2016 02:36 AM
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 10:28 PM
smallest OD coil over / spring perch BadBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2014 12:56 PM
Clearance to spring perch Gearhead1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-07-2014 05:56 PM
