Old 03-06-2014, 01:46 PM   #1
Gearhead1
Drives: 2013 BRZ automatic
Clearance to spring perch
Does anyone know how to determine a minimum safe clearance between the (front) tire and spring perch?
Gearhead1 is offline   Reply With Quote
Old 03-06-2014, 03:14 PM   #2
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
The credit card test has always served me well. If you can easily slide a credit card between the tire and spring perch, then you should be good.
jprice130 is offline   Reply With Quote
Old 03-06-2014, 03:47 PM   #3
wparsons
wparsons's Avatar
I'd personally want a bit more, especially if you plan on cornering hard. As you load up the outside wheel the tire will move towards the perch a tiny bit.
I'd say ~3mm (1/8") is plenty, but you can probably get away with less.
flickr
Old 03-06-2014, 04:01 PM   #4
jprice130
AutoX Nut
Oh yeah, more clearance is always better, but I have used the credit card method on 3 different cars that I autocrossed extensively and never had rubbing issues. With that said, I always used r-compound tires or high-performance street tires, so there is a lot more sidewall stiffness with those tires.
If you're using an all-season tire or anything else with a softer sidewall, then you're right, more clearance (2 credit cards!) might be safer.
Old 03-06-2014, 07:37 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
Paint stick should be safe for most sidewalls.
Gunman is offline   Reply With Quote
Old 03-06-2014, 08:10 PM   #6
Gearhead1
I have just short of 1/4" to the Direzza ZII's, so it sounds like I should be fine for track days. I wouldn't have been as nervous if the clearance was to a smooth surface like the strut, but the perch had me concerned.
Thanks, guys, for the feedback
Old 03-06-2014, 09:20 PM   #7
fstlane
fstlane's Avatar
Drives: BRZ Limited
A 1/4" is more than ample clearance. I ran my Direzza ZII's with less than 2mm of clearance and they didn't rub. I put a piece of masking tape on the perch lip to see if it would rub and ran a day of autocross runs. The perch sits pretty low on the tire sidewall so there isn't much tire flex at that point plus the ZII's have pretty stiff sidewalls. You're good!
fstlane is offline   Reply With Quote
Old 03-07-2014, 05:56 PM   #8
Gearhead1
Thanks fstlane, that totally answered my concerns.
TRD clearance? BadRix Scion FR-S / Toyota 86 GT86 General Forum 7 02-10-2014 11:23 AM
17s & BBK clearance ultra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-04-2014 04:53 AM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
Driveway Clearance? topazsparrow Scion FR-S / Toyota 86 GT86 General Forum 17 06-14-2013 11:37 AM
BRZ front clearance a2cpc BRZ First-Gen (2012+) — General Topics 14 01-23-2013 07:38 AM
