Old 06-05-2021, 10:00 PM   #1
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Which orientation should the oem strut mounts go?
Hi, I remember reading somewhere that these red/green markings are references for installation in the right orientation. Is there a specific way that these are supposed to face on the strut mount? I feel them moving with my fingers when turning the wheel so just want to make sure they are not installed backwards. Thanks!
ItsReiko is offline   Reply With Quote
Old 06-06-2021, 12:19 AM   #2
strat61caster
strat61caster's Avatar
They're symmetric doesn't matter which orientation
ineedyourdiddly
Old 06-07-2021, 02:05 AM   #3
ItsReiko
ItsReiko's Avatar
So I just got it installed and after tightening the strut hat down (suspension not yet installed on car), when I press left and right at two of the corners from above the top hat, the hat has a very small play/wiggle. Is this normal or did I screw something up?
Also, right after installation I took it on a small test drive and while I was stopped, the first couple of steering lock to lock turns I did, near the end of both locks I can hear the spring making crunching noises, like what the springs would sound like when you try to turn the lock nut without holding the shaft.
After about 4-6 lock to locks, the springs did not make this crunching noise anymore, so I assume it was setting itself in, but hopefully that doesn't mean I twisted the shaft doing so? What do you guys think. What I thought would take me 1.5hrs took over 4hrs lol.
Old 06-07-2021, 05:40 AM   #4
strat61caster
Not sure what you mean by wiggle, if everything is torqued properly you should be fine.
Yes springs settling in
The shaft inherently twists, it's unavoidable and isn't catastrophic in small amounts during assembly.
ineedyourdiddly
Whiteline Com 'C' Strut Mounts smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 04-19-2018 01:33 AM
STI Group N Strut Mounts ZC6BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-12-2017 08:08 AM
New Strut Mounts for Coilovers? MJones_RB Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-27-2016 09:24 AM
Rear strut orientation ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 11-08-2015 05:26 PM
WTB: Stock strut assemblies or top mounts sw20kosh Brakes, Suspension, Chassis 1 10-26-2013 03:22 PM
