Drives: 2013 Raven FR-S
Whiteline Com 'C' Strut Mounts
I remember a while back people having problems with these clunking and popping. Does anyone know if Whiteline ever fixed that issue? I think it was related to the open bearings they were using.
Drives: FR-S and Mazda 3 Sky
As far as I remember reading in other threads, they gave up and pulled the plug on those...
That Guy
Drives: 2013 asphalt FRS MT
I noticed that FT86speedfactory still has them on their site. Maybe you should contact them to see if they have any in stock.
That Guy
Drives: '13 DGM BRZ Limited
They changed the bearing, but it didn't fix the issue. They actually sent me a new set with a couple machined washers that they said they were testing. I didn't want to go through the hassle of swapping them to only have issues again so I went with HVT mounts and haven't had any problems.
I still have the Comp-C's NIB if anyone is interested. Otherwise, was just going to throw them up on Nasioc for a WRX/Impreza owner instead. |
#6 | |
That Guy
Drives: Toyota 86
I think its bearing axis should be inclined somewhat.
I've tried conical washers but bearings failed in the same way. |
They still make them, but don't list them for the FRS/BRZ. They don't have issues on the impreza chassis, but something about the strut angle on these cars doesn't play nice with the bearing.
#10 |
Bringing this back from the grave, has anyone ever had a set that didn’t make noise long term??
#11 |
Drives: 2014 GT86
I managed to get wished camber & keep rubber top mounts via other means. -3 at stock height with camberbolts in both holes + powerflex bushing PFF69-801G. Pitty about no non failing bearings revision of compatible Com-Cs for twins, but i got what i wished at end.
#12 |
What a shame. I’m considering group N rubber top hats but they do not have nearly the same benefits as a silent Com C would have.
#13 |
One of the products we'd love to make is a long lasting fixed camber plate with some rubber for reasonable NVH. Got a couple other things in the pipeline in the meantime, but hopefully we can make something like that in the future.
- Andrew |
#14 |
AutoX-10/10ths every run
I'd suggest just buying the RACESENG CASCAMs and be done with it. I have been through the COMCs previously and they never lasted.
http://www.raceseng.com/cascam-caste...ubaru-brz-2013
| Whiteline Com-c top mounts | sw20kosh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 349 | 05-27-2015 06:15 AM |
