FA20ToyBaru
Drives: Manual
Rod Bearings/Main Bearings
So I am now building the block. I finished the valvetrain, trans, and suspension. In my search for information, i have come up short on how to access what bearing sizes i would need. I am going to be using the stock crankshaft. I found that King makes some pretty good bearings that last but im stuck looking at different sizes. I am not going to modify the stock crank, so my question is the following. Where can i find the dimensions for the stock OEM bearings to compare? Also, has anyone used the King XPG bearings on a stock crank? If so what size did you use to provide the correct lubrication and avoid contact |
Drives: Crapcan
You need to go through the procedure in the service manual to determine what size bearings you will need.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
Drives: '13 Whiteout
I have an IAG block and I believe they use those bearings and the New Subaru FA20 DIT WRX crankshaft . Maybe just contact King and ask which bearings you should use then you dont run the risk of using the wrong ones
#4 | |
LMGTFY
Drives: 13 FRS, 91 Miata
The only way to know what size he needs is to remove the ones already in there. Like I said in his other thread. If you are asking these types of questions you really shouldn't be building your own engine. |
FA20ToyBaru
Drives: Manual
Thanks for providing this information. I have not been getting any notifications from this thread. I will use your post as a guide.
FA20ToyBaru
Drives: Manual
Thanks, yea ive talked to a couple of builders that gave me some guidance. I was having a hard time seeing what the oem sizes were. I wanted to see if i should look into standard or get a different size. Since i was going to use a new crank i figured i could go standard but measuring would definitely help. King, Real St, and IAG recommend standard if not using an old crank. I know some like to run tighter and some looser. Ill look into it some more.
FA20ToyBaru
Drives: Manual
Dang bro! Just a negative nancy! We all start somewhere. Thanks, I guess, for your input.
Drives: Crapcan
It is kind of a faux pas to post multiple threads about the same thing in different places. If you look at forum member "Ultramaroon" he has a link to the service manual in his sig. It is best to start at the manual.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | jeepmor (06-17-2021) |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
All FNGs take their lumps, you're no different. I'm a seasoned jeep guy still asking dumb questions in here about this car. Learn to skim off the ribbing and take the info and run with it.
| The Following User Says Thank You to jeepmor For This Useful Post: | Ultramaroon (06-18-2021) |
| Rod Bearings/Main Bearings | Fa20Toybaru | Engine, Exhaust, Transmission | 2 | 06-02-2021 02:15 AM |
| BRZ wheel bearings same as 86? | JackRabbit | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 01-06-2020 02:52 PM |
| Wheel bearings gone bad | rustymuffler | Issues | Warranty | Recalls / TSB | 25 | 05-02-2019 12:21 PM |
| The OEM rod bearings debate | nelsmar | Engine, Exhaust, Transmission | 58 | 12-02-2013 01:51 PM |
