Old 06-01-2021, 11:30 AM   #1
Fa20Toybaru
FA20ToyBaru
Fa20Toybaru's Avatar
Drives: Manual
Rod Bearings/Main Bearings
So I am now building the block. I finished the valvetrain, trans, and suspension. In my search for information, i have come up short on how to access what bearing sizes i would need. I am going to be using the stock crankshaft. I found that King makes some pretty good bearings that last but im stuck looking at different sizes.
I am not going to modify the stock crank, so my question is the following. Where can i find the dimensions for the stock OEM bearings to compare? Also, has anyone used the King XPG bearings on a stock crank? If so what size did you use to provide the correct lubrication and avoid contact?
Fa20Toybaru is offline   Reply With Quote
Old 06-01-2021, 03:15 PM   #2
jrhudson
Drives: 2016 scion frs
Im not sure if this has the exactly the correct info you need but shows how thick your bearings should be and clearances for most of the motor
https://www.subarucar.net/sites/suba...FA20D_DOHC.pdf
jrhudson is offline   Reply With Quote
Old 06-02-2021, 01:15 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
IMO if you are asking these questions you would be better off paying someone to do it.
The only real way to know is to look at the ones already in the block.
The Following User Says Thank You to x808drifter For This Useful Post:
Wally86 (06-02-2021)
Wheel bearings gone bad rustymuffler Issues | Warranty | Recalls / TSB 25 05-02-2019 11:21 AM
Bent cam bearings/rod? Gost Issues | Warranty | Recalls / TSB 16 02-19-2018 08:56 PM
Bearings Wanted Lunatic Engine, Exhaust, Transmission 0 01-29-2018 02:52 PM
The OEM rod bearings debate nelsmar Engine, Exhaust, Transmission 58 12-02-2013 12:51 PM
