Drives: 2015 Scion FRS
Hey guys,
I have read a bunch of the forums but this is my first time writing one, so hello! I drive a 2015 FRS with just under 50k miles and recently replaced my clutch. I could tell my old one was going because I lacked acceleration and could tell it was starting to slip, so I installed a new ACT clutch. After I put the car back together, I started it and got the following codes, P0011, P0016, P0018, P0021. The car will not idle for longer than 2 minutes and while taking it around the block for a test drive, the car shuts off and cuts the engine when I slow down and rpms drop below 1k (basically the car can not hold an idle). I took it to dealer a few weeks ago and they said it might need new oil control values and have to do with the timing chain. I am taking it to a tuning shop in a few days for a second opinion. Was wondering is anyone on here has experienced these issue or had any suggestions? I have read so many forums and webpages and some say I need to replace the ECU and all of the items I stated and it still might not fix the issue. At this point I am just lost. Hope someone can help. Thanks in advance |
#2 | |
Time Traveller
#3 | |
I also did just replace the oil 2 weeks before I replaced the clutch. It was a little low when I replaced the oil as well fyi |
Drives: '13 Whiteout
Start with the oil control valves.it doesn’t take much for them to get clogged
Drives: RX-7 / BRZ
Since it is both banks I wouldn't start with the OVC's for diag. All of them won't likely go out at once. If this happened while doing a clutch this is where you need to start your search. I'd start with the reluctor wheel. It works with both crank and cam sensors. It is the big wheel behind the clutch assembly. Make sure it is aligned properly on the pin and the correct direction. Once your past making sure you didn't botch up the installation/wiring then I'd move towards the front of the engine. Start with a good scan tool and watch the VVT sensors while you have another person drive. Are they all pegged at 0 or are they all moving in a similar fashion?
You don't do the ecu until the last steps, if the problem still isn't fixed or if needed.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
Time Traveller
| P0021 and P00C | Kiske | Issues | Warranty | Recalls / TSB | 10 | 06-02-2021 11:54 AM |
| P0011 & P0021 | BlueLine | Issues | Warranty | Recalls / TSB | 14 | 09-17-2020 09:02 AM |
| P000A and P0011 | Riftur | Issues | Warranty | Recalls / TSB | 5 | 02-13-2017 09:32 PM |
| DTC: P0335, P0011, P0345, P0340 | SolderGlob | Issues | Warranty | Recalls / TSB | 8 | 01-13-2017 01:37 PM |
| Considering buying a lemon buyback BRZ, have repair history (P000A and P0011 codes) | ZDan | Issues | Warranty | Recalls / TSB | 21 | 02-19-2016 02:51 PM |
