Old 02-12-2017, 10:57 AM   #1
Riftur
Riftur's Avatar
P000A and P0011
Today I started my car and got P000A and P0011 codes and the track control light was on and the Cel light. Car didnt seem to run different. I cleared the codes and restarted the car and it didnt come back in the 5 minutes I let it run for. Should I be worried. I saw some stuff on the net and I think i read there is a TSB for the codes. Any info is appreciated.
Riftur is offline   Reply With Quote
Old 02-12-2017, 12:05 PM   #2
humfrz
I'd suggest you take it out and drive it around for a while.
If the codes don't come back, I'd just chalk it up to an engine hiccup and not worry about it.
humfrz
Old 02-13-2017, 04:56 AM   #3
steve99
Yeah their cam position correlation codes
have a look at the tsb section for avcs, rough idle, cam position idle instability tsb,s theirs a few unfortunatly difficult to diagnose down to a single compent.
http://www.ft86club.com/forums/showthread.php?t=21868
might be a simple as an ecu reflash or cam sensor shim, or require cam sproket actuator
oil control valves or even new ecu hardware
Old 02-13-2017, 02:00 PM   #4
Scarpa
Drives: 2015 FR-S
I've been dealing with P0000B since I bought my car (MY15, used)
It comes on, triggers limp mode like yours, clears itself in a couple ignition cycles. Last dealer work replaced the ECU but the code keeps coming back, just less often.
At this point I pretty much ignore it and let it go away on it's own. I might take it back to dealer near end of warranty to see if they can clear it for good.
Scarpa is offline   Reply With Quote
Old 02-13-2017, 05:50 PM   #5
steve99
keep onto it its a diffucult one for them to find, but its best you get it sorted the parts can be quite expensive
Old 02-13-2017, 09:32 PM   #6
CTB727
Drives: 2013 Subaru BRZ
P000B was an oil control actuator for me. P0016 came up about 4 months later.
CTB727 is offline   Reply With Quote
Cylinder Head Assemblies causing P000A & P000C? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 3 01-23-2017 05:37 PM
DTC: P0335, P0011, P0345, P0340 SolderGlob Issues | Warranty | Recalls / TSB 8 01-13-2017 01:37 PM
Considering buying a lemon buyback BRZ, have repair history (P000A and P0011 codes) ZDan Issues | Warranty | Recalls / TSB 21 02-19-2016 02:51 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 01:48 AM
