Old 02-14-2016, 12:46 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Considering buying a lemon buyback BRZ, have repair history (P000A and P0011 codes)
I am thinking about buying a 2014 BRZ limited at nearby dealership that sells a lot of lemon-law buyback cars (including this one). They gave me the service history on this car, from which:
1/22/2015 4480 miles: CEL, P0011 camshaft bank 1. Tech replaced right intake oil control valve
2/27/2015 4684 miles: CEL and car sputters, codes P000A and P0011, checked VVT angles 4* difference betweeen L R banks, replaced ECM and right intake cam sprocket
3/25/2015 4696 miles: CEL on, P0011. Checked intake advance angles 75* difference from left to right bank. Replaced cam sprocket and ECM ACVS solenoid is from good lot per tech line. Advance angles are still off cam timing is go
The dealership the car is at now says it is fixed, but the above is the last note in its service history and doesn't exactly suggest that: "Advance angles are still off".
I drove the car and it seemed perfectly fine. Dealer says if it hadn't been fixed it would be tripping the CEL and not running right.
Has anyone had similar issues to these, and were they ultimately fixed?
Thanks for any words of wisdom!
Old 02-14-2016, 01:03 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This thread should help you:
http://www.ft86club.com/forums/showthread.php?t=29729
http://www.ft86club.com/forums/showp...&postcount=205
http://www.ft86club.com/forums/showp...&postcount=157
His engine ended up being replaced due to the damage, also his ECU was believed to be the initial cause of failure because the car ran super lean so the ecu was replaced as well.
So honestly if you can get it with it's warranty in tact, then get it, the ECU being replaced as well as the troubled and damaged cam sprockets being replaced by the dealer is a good sign.
Also important note the codes mentioned were in a TSB that involved the AVCS hopefully they followed these steps, double check it with them, if you look through you can see what they replaced was recommended by subaru:
http://www.ft86club.com/forums/attachment.php?attachmentid=20080&d=1352490977
Old 02-14-2016, 01:32 PM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Test drive it hard. If it goes bad, sometimes you can buy small guarantees.
Packofcrows is offline   Reply With Quote
Old 02-14-2016, 02:28 PM   #4
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
How much are you paying for it. You can get them that are not lemons fairly cheap if you are willing to go with used
But if you have plans on ripping it apart to re-build and its cheap, sure go for it
RichardsFRS is offline   Reply With Quote
Old 02-14-2016, 03:13 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Nope. Sounds like serious engine problems
N1rve
Old 02-14-2016, 03:29 PM   #6
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Depending on what you want to do with the car it could be a good buy if the price is right.
Gear_One_Performance is offline   Reply With Quote
Old 02-15-2016, 07:41 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think I'm gonna hold out for a car that hasn't had issues. This one would save me a few bucks, but given the few miles on it since repairs, I have to wonder...
Old 02-15-2016, 10:01 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Gives me a bit of pause to think that there might be latent internal engine damage...
http://www.ft86club.com/forums/attac...0&d=1352490977
It looks like they at least sorta followed this. First replaced OCV, then cam sprocket and ECM, then another cam sprocket and ECM again.
Looking at other threads, I wonder if it could be a clogged inline oil screen filter to one or both cams.
Their asking price of $22k to me seems more than fair for a non-lemon, but high for a branded lemon with known history of problems. I'm not interested in dealing with major problems, would rather pay more for less risk.
Plan for car would be to drive drive drive it for many years. And occasional track days It would take the place of my '01 S2000 which has served as my daily for the past 9 years.
I'm not worried about reduced value due to lemon title, but don't want to have to deal with major issues, either.
What I would *really* want: a 2+2 S2000 fixed-roof coupe. The FR-S/BRZ are soooo close, but honestly the engine failures from DI injectors and AVCS issues have me spookified...
Old 02-15-2016, 10:09 AM   #9
-Phil
Drives: Rb25 neo brz
I would Send the oil off to Blackstone That'll give you an idea as far as engine wear goes, 22k does seem a bit much though
-Phil is offline   Reply With Quote
Old 02-15-2016, 11:13 AM   #10
I'll second this, if you can get the seller to hang on to it pending a response from Blackstone this should definitely help you make your decision.
Old 02-15-2016, 02:17 PM   #11
RichardsFRS
22k for a car that you already know sucks? Fuck that
you can get a new one close to that, you can go get one that runs cheaper than that
RUN
Old 02-15-2016, 02:54 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
RUN
Yeah, only way I'd do it was if:
1) I could assure myself the engine is fine
and
2) the discount relative to a pristine-title no-problem-history Limited was a lot more than ~$1500
I figure the best deal I could get on a new Limited would be ~$27k, izzat about right? Wouldn't mind letting someone else take the initial depreciation hit, but might go that route. Or just keep S2k...
Old 02-15-2016, 03:39 PM   #13
grinerizer
Drives: 2014 Subaru BRZ Limited SWP
To ensure the engine is fine, contact a local subaru dealer and have them do a pre-purchase inspection.
How many miles are on the vehicle now? I'm not sure regarding Lemon Buybacks, but in most cases, the original warranty should still be applicable. I do know they are canceled when a car is totaled.
pm me the VIN. I'll check things out from my end.
grinerizer is offline   Reply With Quote
Old 02-15-2016, 03:46 PM   #14
RichardsFRS
There are more than plenty low milage ones you can probably snag under 20. Mine was 15700 but it had 43800 on it. BRZs are a little harder to come by. But FRSs are out there everywhere. Pick up a 2015 that was upgraded for a 2016. Don't buy this car knowing it's a lemon. Buy one with a few miles and let someone else eat the depreciation. After owning this car I think 27 is reasonable. Brilliant little machine.
Cylinder Head Assemblies causing P000A & P000C? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 3 01-23-2017 05:37 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 01:48 AM
BRZ- Lemon? laxfogo Issues | Warranty | Recalls / TSB 24 04-05-2013 05:15 PM
Lease/BuyBack and upgrades Chinadian Scion FR-S / Toyota 86 GT86 General Forum 15 01-08-2013 08:35 AM
