Old 05-18-2021, 07:49 AM   #1
Sniepster
Drives: 2013 Toyota 86
Possible coil bind?
So i've jacked the car up today to diagnose a strange metallic sound i hear from time to time (it sometime sounded like the exhaust was banging about), we were not able to find anything however we did notice something strange on the rear springs, it looks like the bottom coils have come together as they also have marks in them, is this what coil bind looks like? The car has Eibach lowering springs on stock shocks. If it is coil bind does this mean the springs can break under hard cornering? What can I do to fix this?
Picture attached.
Sniepster is offline   Reply With Quote
Old 05-18-2021, 08:22 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Normal, and It's what they are designed to do. Eibachs are progressive, so they get stiffer as they compress. They do this using the pitch between coils and reducing active coil count when they compress. That isolator sleeve on the spring protects the coils from rubbing through the next coil's paint.
The sound you're hearing could just be it shifting on it's perch as it's loaded/unloaded.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
strat61caster (05-18-2021)
Old 05-19-2021, 03:25 AM   #3
Sniepster
I did not touch the coils to get a feel for them, but the two different looking coils are covered in some kind of rubber and they're supposed to touch, am i understanding this correctly?
Old 05-19-2021, 03:17 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Yes
Coil Bind/Pillow Ball/Spherical Bearing Tein Flex A VOSS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 12-19-2019 08:29 PM
Clicking/tapping noise from front suspension, coil bind? jfarkas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-12-2018 10:48 PM
HKS V3 USERS, in a bind maybe you can help nickmerronesucks Forced Induction 2 03-10-2017 01:42 AM
Spring bind - Raceseng CasCam & Ohlins RT 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-14-2015 02:56 PM
