Old 07-14-2015, 09:56 AM   #1
1Cor10:23
1Cor10:23's Avatar
Spring bind - Raceseng CasCam & Ohlins RT
Hi everyone,
Lately I've been experiencing a bit of spring "twang" but only happens at right about full lock (left sounds a bit worse than right); basically turn to full lock, hear a tiny bit of spring bind, unwind about 10 degrees and you get a bit more spring bind release noise. Other than approaching lock and releasing from lock (about 10 degrees of rotation I'd say), no other noises from coils.
I'm a bit perplex since the @Raceseng perches come with radial bearings, which usually clear up an issue like this.
Getting an alignment on Thursday so will ask my tech to take a look. Would appreciate any thoughts in the meantime.
Thanks!
Old 07-14-2015, 01:17 PM   #2
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
hmm.. i dont know if my issue is spring bind but for sure after installing the plates, at a full lock, i hear a weird creak. both sides. Am I supposed to grease something? OEM springs here.
mokinbird87 is offline   Reply With Quote
Old 07-14-2015, 01:21 PM   #3
1Cor10:23
1Cor10:23's Avatar
@mokinbird87 I used to run the plates on stock suspension, didn't have the creak noise
I talked to jarett, he suggested I take a look at the spring perch to check if it seized.
Sent from my SGH-I317M using Tapatalk
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
mokinbird87 (07-14-2015)
Old 07-14-2015, 02:39 PM   #4
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Check your preload. my coils did the same thing. It created a binding noise of the springs. I adjusted the top collar to tighten the preload and it was good.
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
1Cor10:23 (07-14-2015), kevaughan (04-16-2024)
Old 07-14-2015, 02:56 PM   #5
1Cor10:23
1Cor10:23's Avatar
@NyC Zn6 will do, I recall ohlins wants 2mm preloaded, my alignment guy (super knowledgeable and races) suggested just snug. Hopefully it's as simple as this...
DIY Raceseng CasCam plates for KW V3 olorin DIY (Do-It-Yourself) Guides 12 02-19-2017 01:32 AM
CounterSpace Garage || JRZ|KW|Tein|Bilstein|Ohlins|MCS|SPL|Swift|Raceseng || CounterSpace Garage Brakes, Suspension, Chassis 45 11-01-2016 11:44 AM
FS: Bilstein B14 PSS Coilovers with Raceseng CasCam Plates dmarkey Brakes, Suspension, Chassis 2 06-02-2015 04:44 PM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
Raceseng | CasCam - Caster + Camber Plate Black Friday Sale Raceseng Brakes, Suspension, Chassis 0 11-30-2013 11:09 AM
