Old 05-13-2021, 04:22 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Alignment
How much ground clearance is needed for a alignment? Im having a hard time getting my car setup with one due to them saying its too low. Also when i bring my ride height up for the alignment will it throw off geometry again when goin back to my preferred height
IsaiahW is offline   Reply With Quote
Old 05-13-2021, 04:26 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It depends on the alignment shop. I have never gotten a complaint even after watching them stack boards to get it on the rack.
Old 05-13-2021, 04:35 PM   #3
IsaiahW
IsaiahW's Avatar
Yah I believe its pure laziness because basically all of them around me says its too low but firestone particularly said they need atleast three finger clearance from tire to wheel well for the sensors to go on which i dont have even though i slapped on stock size wheels for the alignment instead of my 18s
Old 05-13-2021, 04:41 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Both the shops I trust have alignment racks that use these types of sensors. Fender clearance isn't an issue.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
IsaiahW (05-13-2021)
Old 05-14-2021, 08:58 AM   #5
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
That's quite the bend in your lip. I'd keep an eye on the pressure of that tire just in case. (I'm aware that the air seal is well below that, but precautions are important)
Try a performance shop. They would be dealing with lowered cars frequently.
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
Wally86 (05-14-2021)
Old 05-14-2021, 09:37 AM   #6
Just how low are you?
I had zero issues getting alignments done on my FRS and it was dropped 1.5".
Old 05-14-2021, 11:00 AM   #7
Grady
Grady's Avatar
Had the same issue and mine was only dropped an inch. Subaru dealer said no, they had the old alignment rack from the Hummer dealer. They sent me to their sister Lexus dealer. That was fun having a yellow BRZ in the sea of silver SUV’s. Had an 86 acquaintance said he could. He pooped my STI front lip loose and the middle drug coming off the rack. Got tired of dealing with it so bought all the stuff to align the car myself. Search around for a performance shop or a shop with a flat alignment rack. It will cost more but less chance of them tearing something up.
Old 05-14-2021, 01:10 PM   #8
IsaiahW
IsaiahW's Avatar
It's more so an issue where the ones with in-ground racks use the tire mount sensors instead of the rim mount sensors so no matter where I go my car is either too low or they can't fit the sensors on the tire I just went to a shop about an hour from me that said they could do it I get there they said they sensors won't fit and they didn’t even wanna adjust the ride height on coil-overs to do the alignment and ill pay more but I spoke to a tech he said it used to never be an issue it’s just now shops are not adapting to the car community
Old 05-14-2021, 07:00 PM   #9
Grady
Grady's Avatar
Ok here is your list.
https://www.kwik-lift.com/
https://www.longacreracing.com/produ...k-Set™-Adapter
https://www.longacreracing.com/produ...-Magnets-(pair)
https://quicktrickalignment.com/prod...shipping-usps/
https://quicktrickalignment.com/product/qtsw416474/
Boom never pay for alignments again. To do 4 wheel you will need string and patience.
The Following 2 Users Say Thank You to Grady For This Useful Post:
IsaiahW (05-14-2021), Wally86 (05-20-2021)
Old 05-14-2021, 09:01 PM   #10
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
A good investment for the long run.
scion fr-s is offline   Reply With Quote
The Following User Says Thank You to scion fr-s For This Useful Post:
Old 05-19-2021, 02:49 PM   #11
theneptune86
Drives: Neptune Blue 2019 Toyota 86
At our shop we have a drive on hoist that's flush with the ground when its fully lowered. It also has the rim mounted sensors.
I think at the end of the day, a lowered/track stanced/stancey boi car seems intimidating, and is seen as a potential $$$ loss for a straight time tech, so they come up with an excuse as to why it can't be done or wont be safe or whatever. Kinda sad.
That said, I am excited to be learning alignments, and look forward to doing them for local car guys. A great opportunity to work on a lot of cool cars outside of the Toyota range IMO.
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
theneptune86 is offline   Reply With Quote
Old 05-19-2021, 03:11 PM   #12
IsaiahW
IsaiahW's Avatar
We need more ppl like you in my area(757)too much laziness i had to schedule a alignment with a truck alignment company and the soonest was june 16th.
Alignment 86Ryan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-05-2018 08:37 PM
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Just got an alignment.. Scalzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 06-01-2013 10:39 PM
