Old 05-12-2021, 07:35 PM   #1
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Torsional Vibration Damper - FA20
Engine Labs article on the development of the Fluidampr for the FA20.
It has in interesting comparison between the various alternative designs of crank pulleys using a twin as a test mule.
https://www.enginelabs.com/news/gues...rzwrx-dampers/
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post:
DarkPira7e (05-12-2021), Jdmjunkie (05-12-2021), NoHaveMSG (05-12-2021), Wally86 (05-13-2021)
Old 05-13-2021, 09:03 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Six year old article... I wonder if anyone is running this?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is online now   Reply With Quote
Old 05-13-2021, 09:08 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It looks to be an old article. Do they want to sell the old stock?
Old 05-13-2021, 09:25 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
For anyone who wants to dig a little deeper: https://www.ft86club.com/forums/show....php?p=3302739
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
jrhudson (05-13-2021), RToyo86 (05-13-2021)
Old 05-13-2021, 09:41 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I knew I had seen this data somewhere. Still, a nice re-read
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 05-13-2021, 10:06 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The one bit of data that the engine labs link has that this one doesn't is a dyno.
The Fluidamper made more power than the OEM and the lightweight lost power.
Then of course there is no way to verify said dyno sheet.
Old 05-13-2021, 10:28 AM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
On the plus side, if a shop wanted too, they could easily replicate this experiment.
Old 05-13-2021, 10:47 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Interesting. What I took from this is when/if I ever lighten the flywheel I will add this to parts list.
Old 05-13-2021, 10:59 AM   #9
DarkPira7e
DarkPira7e's Avatar
To be honest, I'm considering this. I have the FluidAmpr and a lightweight crank pulley. After getting my tune dialed in, I wanted to swap them and see what differences I can tell.
I'm looking for perceived engine roughness, and noise mostly. Still not sure if I'll make the effort just yet but I'll post it I do. My build is a long ways out still do don't expect anything soon
Old 05-13-2021, 12:51 PM   #10
chipmunk
Drives: _
OEMs spend a lot of time and resources to tune the whole accessory drive system - rotational inertias, damping coeffs, and frequencies. Unless you tune the whole system including flywheel and all accessories on the belt, it's not wise to change one pulley or flywheel and leave the rest stock. Sometimes torsional dampers work better, some other times having a higher polar inertia work better to tune out the firing order vibrations (2nd in our case).
Higher the inertia, lower the "shock loading". That's why heavier flywheels give smoother ramp ups and ramp downs.
chipmunk is offline   Reply With Quote
Old 05-13-2021, 02:02 PM   #11
Capt Spaulding
Persona Non Grata
Thanks for the insights guys. Sorry if it's old hat to most of you. I noticed the article is a bit long in the tooth (as am I). I ran across it reading up on harmonic balancers/torsional dampers which led me to Fluidampr's site. As a non-engineer what I found most interesting was the theory regarding what's happening. For the mechanical engineering unwashed such as myself Fluidampr's website has some interesting reading material - including a link to another old article about torsional vibration issues with Cosworth's old CA F1 engine (an NA 20,000 rpm, 2.4L V8).
For me anyway, it put to rest the "high performance lightweight crank pulley" fable.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 05-13-2021, 03:15 PM   #12
Project_1796
Drives: Scion FRS 10 series
I have run the Fluidampr for 2 years as a daily, the engine powerband feels smoother than stock, no issues at all. It's not a power adder, it will help the engine in the long run. Here is another article from Motoiq https://motoiq.com/fluidampr-the-independent-test/
Project_1796 is offline   Reply With Quote
The Following 4 Users Say Thank You to Project_1796 For This Useful Post:
Capt Spaulding (05-13-2021), DarkPira7e (05-13-2021), Wally86 (05-13-2021), whataboutbob (05-14-2021)
Old 05-13-2021, 05:16 PM   #13
DarkPira7e
DarkPira7e's Avatar
There's absolutely nothing wrong with sharing good, helpful, nonspeculative information I'd rather see an article like this pop up twice a month than shenanigans about the next gen BRZ that people are guessing about
Old 05-13-2021, 06:26 PM   #14
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I appreciate it. I had never heard of one.
If this helps make the motor sound less like a diesel, I'm all for it
The Following User Says Thank You to Wally86 For This Useful Post:
Performing FA20 swap with new FA20 Ctoner2653 Engine Swaps 8 09-24-2021 08:40 AM
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 07:17 AM
FRS VS BRZ Damper (strut) kilohercas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-24-2015 03:11 PM
Damper crosstalk ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-01-2013 02:21 AM
