Old 05-11-2021, 05:40 AM   #1
grumpysnapper
grumpysnapper's Avatar
AP Racing (Essex) brakes - glowing... (and brilliant)
Had the AP Racing Essex Sprint kit now for about 5 years, and a fast mountain run last night reminded me (again) what a terrific set of brakes they are.
Strong, zero fade, great feel and they fit in 16" wheels.
Callipers still look like new after many thousands of km's on dirt, in mud and on tarmac.
Last edited by grumpysnapper; 05-13-2021 at 08:57 AM. Reason: forgot to credit as an Essex kit
grumpysnapper is offline   Reply With Quote
The Following 6 Users Say Thank You to grumpysnapper For This Useful Post:
Brz-123 (05-11-2021), JRitt (06-02-2021), MICHAEL450f (05-21-2021), soundman98 (05-11-2021), surfwaxsmitty (05-21-2021), whataboutbob (05-19-2021)
Old 05-11-2021, 06:59 AM   #2
Brz-123
Nice one. Which 16 inch wheels do they fit over? Will they fit behind the OE 17inch wheels?
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following User Says Thank You to Brz-123 For This Useful Post:
grumpysnapper (05-11-2021)
Old 05-11-2021, 07:23 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Brz-123: check that kit's page for compatible wheels on vendor's page, where "Both kits will fit under certain 17" wheels, but neither will fit OEM wheels without a spacer. Wheel fitment templates available on our site". Also check thread related to kit on this forum. Third post has list of wheels that clear. Regarding OE wheels:
"* 2013+ USDM OEM BRZ or FR-S front wheels, 10mm spacer
* OEM NZDM Gt86 (by enkei)16x6.5 +48, needs at least 8mm spacer"
10mm spacer means that if slipon spacer type used you need also extended studs (with stock studs & lugnuts upto 3mm slipon spacer is safe). If it's bolton spacer, that limit goes away.
The Following User Says Thank You to churchx For This Useful Post:
Old 05-11-2021, 07:32 AM   #4
grumpysnapper
These are Volk (Rays) CE28N 16x7 +33, with heaps of room to spare.
I believe a spacer is required for OEM 17's.
The Following User Says Thank You to grumpysnapper For This Useful Post:
Old 05-16-2021, 08:02 PM   #5
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
next time hit it with a laser temp gun and get back to us.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 05-18-2021, 11:27 PM   #6
jflogerzi
jflogerzi's Avatar
What pads? I run street pads for DD and canyon runs and I don't think they would be liked ring pushed like that
2013 Series 10 FRS #553
Old 05-19-2021, 08:11 PM   #7
grumpysnapper
Now running Endless MX72, which seem to be very consistent over a wide range of temps.
Old 05-19-2021, 08:11 PM   #8
jflogerzi
jflogerzi's Avatar
Squeal on street in low speed braking?
Old 05-21-2021, 01:13 AM   #9
grumpysnapper
Just going through the process of quietening them down now.
After bedding in, I usually wait a while, then depending on the edge wear patterns, will gently chamfer the edges.
I also start the copper paste applications on piston contact points and backing plate (sliding edge) contact points.
Takes a little while to get right, but generally works in the end.
FS: Racing brakes and stuff Touge_Monster Brakes, Suspension, Chassis 1 06-20-2021 11:13 PM
Reconditioning AP Racing Sprint brakes tanner CANADA 9 08-20-2018 09:20 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Racing Brakes 13" F&R Kit Reviewed!!!! F1fletch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-04-2015 09:01 PM
Enkei Racing RPF1 17x9.0 +35 / 5x100 SBC (Super Brilliant Coat) Groupbuy CounterSpace Garage Groupbuys 187 02-13-2014 10:01 PM
