AP Racing (Essex) brakes - glowing... (and brilliant)
Had the AP Racing Essex Sprint kit now for about 5 years, and a fast mountain run last night reminded me (again) what a terrific set of brakes they are.
Strong, zero fade, great feel and they fit in 16" wheels. Callipers still look like new after many thousands of km's on dirt, in mud and on tarmac. Last edited by grumpysnapper; 05-13-2021 at 09:57 AM. Reason: forgot to credit as an Essex kit |
| The Following 6 Users Say Thank You to grumpysnapper For This Useful Post: | Brz-123 (05-11-2021), JRitt (06-02-2021), MICHAEL450f (05-21-2021), soundman98 (05-11-2021), surfwaxsmitty (05-21-2021), whataboutbob (05-19-2021) |
#2 |
Nice one. Which 16 inch wheels do they fit over? Will they fit behind the OE 17inch wheels?
Sent from my SM-G781B using Tapatalk |
| The Following User Says Thank You to Brz-123 For This Useful Post: | grumpysnapper (05-11-2021) |
#3 |
Drives: 2014 GT86
Brz-123: check that kit's page for compatible wheels on vendor's page, where "Both kits will fit under certain 17" wheels, but neither will fit OEM wheels without a spacer. Wheel fitment templates available on our site". Also check thread related to kit on this forum. Third post has list of wheels that clear. Regarding OE wheels:
"* 2013+ USDM OEM BRZ or FR-S front wheels, 10mm spacer * OEM NZDM Gt86 (by enkei)16x6.5 +48, needs at least 8mm spacer" 10mm spacer means that if slipon spacer type used you need also extended studs (with stock studs & lugnuts upto 3mm slipon spacer is safe). If it's bolton spacer, that limit goes away. |
| The Following User Says Thank You to churchx For This Useful Post: | grumpysnapper (05-11-2021) |
#5 |
I just Drive.
Drives: in the womb still
next time hit it with a laser temp gun and get back to us.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#6 |
What pads? I run street pads for DD and canyon runs and I don't think they would be liked ring pushed like that
![]() Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
#7 |
#8 | |
#9 |
Just going through the process of quietening them down now.
After bedding in, I usually wait a while, then depending on the edge wear patterns, will gently chamfer the edges. I also start the copper paste applications on piston contact points and backing plate (sliding edge) contact points. Takes a little while to get right, but generally works in the end. |
| FS: Racing brakes and stuff | Touge_Monster | Brakes, Suspension, Chassis | 1 | 06-21-2021 12:13 AM |
| Reconditioning AP Racing Sprint brakes | tanner | CANADA | 9 | 08-20-2018 10:20 AM |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 06:53 PM |
| Racing Brakes 13" F&R Kit Reviewed!!!! | F1fletch | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 06-04-2015 10:01 PM |
| Enkei Racing RPF1 17x9.0 +35 / 5x100 SBC (Super Brilliant Coat) Groupbuy | CounterSpace Garage | Groupbuys | 187 | 02-13-2014 11:01 PM |
