Old 05-08-2021, 08:57 PM   #1
Nigruto
Nigruto's Avatar
Drives: Toyota 86 2013 Manual
Tire sizing
Hi all,
In need of some advice with tires. I’m wondering if I can run 255/40 R17 (semis) just on the rears? I wouldn’t be able to do them all around bcuz it will scrub on the front. Or should I go for the current tire size all around with Michelin pilot sports?
My specs are:
Rims are 17x9 +35
Current tyres are 235/45 R17
Nigruto is offline   Reply With Quote
Old 05-08-2021, 11:07 PM   #2
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Originally Posted by Nigruto View Post
Hi all,
My specs are:
Rims are 17x9 +35
Is this car exclusively driven on the street, or does it see any track time?
I would suggest running a 245/40-17 square setup so you can continue to rotate, and just dial in negative camber to ensure they clear the fenders. Assuming you are still on stock suspension and do not want to invest in coilovers just yet, you can install camber bolts to get the camber you need up front. The ET35 offset gives you plenty of inner strut clearance to work with, and the 245's will provide you with plenty of grip no matter how you enjoy the car.
- Ryan
APEX Race Parts is offline   Reply With Quote
Old 05-10-2021, 12:47 AM   #3
Nigruto
Nigruto's Avatar
- Ryan
This car is turbocharged and is only driven on the street. I’m sitting on pedders coilovers but the front will scrub if I go 245 so yes that’s a great suggestion! ill get the camber bolts and see how I go
Old 05-10-2021, 09:07 AM   #4
Vital
Drives: 2015 BRZ
I dont think it should rub/scrub with 245/40 tires. Maybe you need to run some more camber to tuck the tire in.
Vital is offline   Reply With Quote
Old 05-14-2021, 02:24 PM   #5
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
I'm running the same specs for wheels and 245/40/17 tires on coilovers.
Currently with zero fitment/rubbing issues. It may depend on your ride height and camber setup.
You may need to alter if you're going for a track setup or want to be a stanceboi.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 05-15-2021, 10:01 PM   #6
jrhudson
Drives: 2016 scion frs
Not the OP, but when you got that size. Is the handling and turning feel duller? Thats what Ive read people say about that when they go 9” tires. Does the turning feel any different like what ive read about?
My setup will be +400whp. Id like some traction but not change how the car feels when youre going round bends/corners.
jrhudson is offline   Reply With Quote
Old 05-16-2021, 12:21 AM   #7
Nigruto
Nigruto's Avatar
If you have the same wheel specs as me I’d say go 245/40 or 245/45 over 255/40 as I’ve heard the Speedo is less accurate and it is slugging in corners. I decided to stay at 235/45 R17 and just got some yoko AD08R for the rears instead. I am turbocharged sitting at 316hp and I’m gripping well in both wet and dry conditions.
Old 05-17-2021, 06:03 PM   #8
KMA KiCKz
KMA KiCKz's Avatar
I'd say the handling is better but the turning feel does feel "duller" imo.
With the wider tires, I have more confidence making tighter corners than I did on stock tires/specs.
TRD | Brembo | RAYS
Old 05-17-2021, 06:08 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Can also confirm that over 225 width starts to feel duller than a narrow tire.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 05-19-2021, 01:24 AM   #10
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
That's unfortunate. I love the look of widebois but I hope I don't regret it because of downgraded feel.
Plumbus is offline   Reply With Quote
Old 05-19-2021, 06:30 AM   #11
DarkPira7e
DarkPira7e's Avatar
It's still pleasant to drive, just slightly less sharp. It still handles just as well.
I went from 200tw tires to 240tw, so maybe my complaint lies there?
Old 05-19-2021, 08:41 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
I never noticed any "dulling" of steering responsiveness going to lightweight 9" wheels with good (RE71R) 245/40-17 tires. If anything, ightweight 9" wheels with good 245s should should generate more lateral grip per degree of slip angle and hence feel *more* responsive.
Old 05-19-2021, 05:19 PM   #13
deca
Drives: Halo 860
I just switched from 225 RS4s on 17x8 +35 Rota Grids to 255 RT615K+s on 17x9 +35 RPF1s and they definitely feel very different. There's less sharpness/directness to the inputs but it doesn't necessarily feel bad. The car actually seems to want to rotate more on the 255s, which is the opposite of what I expected. I'm on TRD springs and running 3.3F/2R for camber and -0.10F/0R for toe. I was worried about rubbing but have no issues at all.
Won't really know how I feel about the setup until I track it this Saturday. I got the wheels intending to run 245s, but the 255s they came with have a lot of tread left so I'm gonna give them a shot first.
deca is offline   Reply With Quote
Old 05-19-2021, 06:47 PM   #14
RayRay88
Drives: 2017 86 860 Special Edition
All of what you are feeling can be attributed to the change in tire/compound.
In my opinion any dullness or lazy initial response is probably more of a function of a few extra pounds gained between a wider wheel and tire combo vs anything to do with the extra width. Hard to tell without an apples to apples comparison (weight, compound etc.).
RayRay88 is offline   Reply With Quote
plus 1 wheels, tire sizing question soundman98 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2019 05:29 PM
Tire Sizing Questions (Total noob looking for winter tires) AzureShadow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-11-2015 12:24 PM
RTR tire sizing SVThis Tracking / Autocross / HPDE / Drifting 10 02-19-2013 08:10 PM
Wheel Guys Chime In! Need advice on tire sizing Pure Automotive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-17-2013 01:21 AM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
