| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Toyota 86 2013 Manual
Tire sizing
Hi all,
In need of some advice with tires. I’m wondering if I can run 255/40 R17 (semis) just on the rears? I wouldn’t be able to do them all around bcuz it will scrub on the front. Or should I go for the current tire size all around with Michelin pilot sports? My specs are: Rims are 17x9 +35 Current tyres are 235/45 R17 Sent from my iPhone using Tapatalk |
#2 | |
FT86Club Official Vendor
Drives: Launch-Year Whiteout FR-S
I would suggest running a 245/40-17 square setup so you can continue to rotate, and just dial in negative camber to ensure they clear the fenders. Assuming you are still on stock suspension and do not want to invest in coilovers just yet, you can install camber bolts to get the camber you need up front. The ET35 offset gives you plenty of inner strut clearance to work with, and the 245's will provide you with plenty of grip no matter how you enjoy the car. - Ryan |
| The Following 3 Users Say Thank You to APEX Race Parts For This Useful Post: |
#3 | |
This car is turbocharged and is only driven on the street. I’m sitting on pedders coilovers but the front will scrub if I go 245 so yes that’s a great suggestion! ill get the camber bolts and see how I go Sent from my iPhone using Tapatalk |
#4 |
Drives: 2015 BRZ
I dont think it should rub/scrub with 245/40 tires. Maybe you need to run some more camber to tuck the tire in.
#5 | |
Certified Wumbologist
Drives: 2015 Scion FR-S
Currently with zero fitment/rubbing issues. It may depend on your ride height and camber setup. You may need to alter if you're going for a track setup or want to be a stanceboi.
#6 | |
Drives: 2016 scion frs
My setup will be +400whp. Id like some traction but not change how the car feels when youre going round bends/corners. |
#7 | |
If you have the same wheel specs as me I’d say go 245/40 or 245/45 over 255/40 as I’ve heard the Speedo is less accurate and it is slugging in corners. I decided to stay at 235/45 R17 and just got some yoko AD08R for the rears instead. I am turbocharged sitting at 316hp and I’m gripping well in both wet and dry conditions. Sent from my iPhone using Tapatalk |
#8 | |
With the wider tires, I have more confidence making tighter corners than I did on stock tires/specs.
| The Following User Says Thank You to KMA KiCKz For This Useful Post: | jrhudson (05-18-2021) |
#9 |
Rust bucket enthusiast
Can also confirm that over 225 width starts to feel duller than a narrow tire.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | jrhudson (05-18-2021) |
#10 |
Señor Member
Drives: '17 BRZ PP
#11 | |
I went from 200tw tires to 240tw, so maybe my complaint lies there?
#12 |
Drives: '23 BRZ
I never noticed any "dulling" of steering responsiveness going to lightweight 9" wheels with good (RE71R) 245/40-17 tires. If anything, ightweight 9" wheels with good 245s should should generate more lateral grip per degree of slip angle and hence feel *more* responsive.
#13 |
Drives: Halo 860
I just switched from 225 RS4s on 17x8 +35 Rota Grids to 255 RT615K+s on 17x9 +35 RPF1s and they definitely feel very different. There's less sharpness/directness to the inputs but it doesn't necessarily feel bad. The car actually seems to want to rotate more on the 255s, which is the opposite of what I expected. I'm on TRD springs and running 3.3F/2R for camber and -0.10F/0R for toe. I was worried about rubbing but have no issues at all.
Won't really know how I feel about the setup until I track it this Saturday. I got the wheels intending to run 245s, but the 255s they came with have a lot of tread left so I'm gonna give them a shot first. |
#14 | |
Drives: 2017 86 860 Special Edition
In my opinion any dullness or lazy initial response is probably more of a function of a few extra pounds gained between a wider wheel and tire combo vs anything to do with the extra width. Hard to tell without an apples to apples comparison (weight, compound etc.). |
| plus 1 wheels, tire sizing question | soundman98 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-21-2019 06:29 PM |
| Tire Sizing Questions (Total noob looking for winter tires) | AzureShadow | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-11-2015 01:24 PM |
| RTR tire sizing | SVThis | Tracking / Autocross / HPDE / Drifting | 10 | 02-19-2013 09:10 PM |
| Wheel Guys Chime In! Need advice on tire sizing | Pure Automotive | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-17-2013 02:21 AM |
| Plus 0 tire sizing | Brzer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 01-30-2012 09:15 PM |
