Old 10-27-2013, 12:55 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Electric Water Pumps?
Any one considered electric water pumps?
http://www.torquecars.com/tuning/ele...ater-pumps.php
http://www.daviescraig.com.au/Electr...s-content.aspx
Reads positively, reality maybe different.
Old 10-27-2013, 01:36 AM   #2
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
There is a kit available from auto factory using the Daviescraig parts.
Does sound interesting, I dunno how much HP you regain by not using the mechanical pump.
http://www.autofactory.jp/product/to...=s&pm=t&seq=15
ahaghshenas is offline   Reply With Quote
Old 10-27-2013, 01:38 AM   #3
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
And how much heat buildup and loss of coolant circulation would result thereafter?
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 10-27-2013, 02:02 AM   #4
arghx7
Drives: car
I don't trust ANY aftermarket electric water pumps for dependability. The main reason why cars come with them from the factory is for fuel economy. BMW is using them now on their 4 cylinder turbo engine.
Also, there's no proof that a higher flowing water pump is the best return on investment to improve cooling compared to radiator, oil cooler, etc.
arghx7 is offline   Reply With Quote
Old 10-27-2013, 02:31 AM   #5
Captain Snooze
Drives: Red Herring
If the pump was doing its job why would either of these issues occur?
I'm guessing you didn't read the links. It has nothing to do with increasing flow.
"the EWP may provide up to 10kw of extra power and additional fuel savings."
Old 10-27-2013, 02:56 AM   #6
Drift-Office
Not sure, only asked because I had a JZGTE motor come in last week with a stock one, had poor circulation and heat built up so we shut it down, changed out to a manual pump and all was honky-dory there after...
Old 10-27-2013, 12:43 PM   #7
arghx7
Drives: car
Oh I read it.
the electrical system was never designed for it, so now you've got more electrical load on the battery and alternator. The water pump has to be installed and calibrated correctly if you want it to save fuel without overheating your engine. I'd have to see how their rudimentary control system works.
Normally when controlling electric water pumps or throttled mechanical pumps you control to a temperature and/or pressure delta across the engine for maximum benefit. Otherwise you would be left with something like a simple speed and load table which is not going to have the same level of benefit.
It's not just "install this, get 10 horsepower" and you better hope your belt system is going to be reliable after re-routing everything. There's about a gazillion things that can go wrong with such a limited benefit.
Old 10-27-2013, 01:22 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'd question the actual benefit of this. In any kind of sustained high load driving a mechanical pump will be more efficient so it wouldn't really be useful for racing.
For a daily driver, even if the controller was as good as arghx7 would like it to be, I doubt the cost of initial purchase and the increased maintenance intervals would ever be offset by the better mileage.
It might be useful for drag racing.
Old 10-27-2013, 10:24 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
I have always liked the idea of being able to control coolant flow independent of engine speed. With the right controller and correctly sized pump i am sure you could make some performance improvements.
1974 TA22 Celica
2013 86 GT
Old 10-28-2013, 12:13 AM   #10
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
BMW has been using electric water pumps since 2006+ on the 328i, the 2007+ 335i. They are pretty badass. Though like anything with use, they do wear out and stop working properly. Replacement is pricey!
The one linked here looks cheesy actually. I will post a photo of the BMW one tomorrow.
MPI_Jack is offline   Reply With Quote
Old 10-28-2013, 01:16 AM   #11
Allch Chcar
Drives: N/A
Their main advantage is for racing. Where time is money. They're far more expensive than a simple mechanical pump and less reliable.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 10-28-2013, 03:50 PM   #12
Poodles
Drives: 2015 Series.Blue
No offense, but the JZ motors never came with an electric water pump from the factory...
I'm with you though on not liking them as it's risky. Now an in-line secondary pump isn't a bad thing...
Old 10-28-2013, 05:47 PM   #13
Drift-Office
My bad - you're absolutely right! *Mild mechanical dyslexia* I was thinking hydro clutch fan - but the one in question last week had an electric water pump which was not cutting it.
Cheers!
Old 10-28-2013, 08:24 PM   #14
Poodles
Yeah, like most things electric, the OEM's are better than the aftermarket (e-fans also come to mind)
The hydrofan is great, but it's expensive to maintain here as the parts are rare and when you do find them, they're used...
Please read if swapping fuel pumps Dipstik-sportech Forced Induction 5 06-17-2013 02:39 PM
*** Introducing the SBD290 DROP-IN Fuel Pumps for the BRZ/FRS/GT86 *** Visconti Engine, Exhaust, Bolt-Ons 21 03-08-2013 01:50 AM
SEMA 2012 Coverage - Deatschwerks Fuel Pumps and Injectors *Video Interview* Circuit Motorsports Engine, Exhaust, Transmission 0 11-13-2012 07:40 PM
