Old 04-25-2021, 11:25 PM   #1
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Sold: 2018 BRZ 6-Speed ABS Pump VSC Module (Track Mode)
2018 Subaru BRZ ABS Pump VSC Module (Sold)
$150 + Shipping
This unit came from a 6-speed BRZ Premium with 11k miles. If you install this in your 2012-2016 BRZ/FR-S you will get the updated 2017+ 'Track Mode'. The unit has serial number 27536CA050 (confirmed to have 'Track Mode' programming).
I can ship the VSC module only and to save several pounds on shipping if you would like. You only need the VSC module part to do the upgrade.
This mod is super easy to install. It is plug-and-play for 2015-2016 cars, while 2012-2014 cars require a repin. Here is the install guide: https://www.ft86club.com/forums/showthread.php?t=140946
Mike_ZN6 is offline
Old 04-28-2021, 03:12 PM   #2
Satarial
Drives: Subaru brz
Hello, Is it for MT or AT car?
Satarial is offline
Old 04-28-2021, 07:53 PM   #3
Mike_ZN6
Mike_ZN6's Avatar
It came from an MT car. I just sold it, though.
Mike_ZN6 is offline
Old 04-28-2021, 07:54 PM   #4
Mike_ZN6
Mike_ZN6's Avatar
SOLD
Mike_ZN6 is offline
Chinese speed/auto lock module blinking hazard issue aznchris Electronics | Audio | NAV | Infotainment 21 12-31-2019 03:12 AM
Speed Sensor Bases Limp mode after new tires MrSlay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-30-2018 10:31 PM
BRZ/FRS ABS Module/Pump/Valving Grambi Brakes, Suspension, Chassis 4 08-22-2015 02:59 PM
