Old 04-20-2021, 01:40 PM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
How hard is it to get these off?
So I’ve done my fair share of plastidip in the past but the gaps in the Toyota emblem is going to make this difficult. How hard is it going to be to take the Toyota emblem off of the front and the rear of the car so I can spray it black and put it back on there?
Jstyle is offline   Reply With Quote
Old 04-20-2021, 01:43 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's not tough, but you need to be patient. Get a hair dryer on it for a bit and it should come off easier. you can use fishing line/floss around the edges, but I think there are alignment pins in the back one so you can't floss straight through it. Unsure about the front.
Anyway, heat = easy mode
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 04-20-2021, 02:07 PM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
Look up the Dip Your Car videos on Youtube. They do all the emblems on the cars. Plastidip is supposed to cut along sharp lines. This should be easy enough to do on the car if done right.
Jdmjunkie is offline   Reply With Quote
Old 04-20-2021, 02:40 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Heat and some tooth floss can work. Some use wire.
I can't remember how much they are but you can buy black Toyota emblems.
Old 04-23-2021, 12:44 PM   #5
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
As stated by others, Heat and floss. You can use a heat gun but a hair dryer would also suffice.
There are plenty of youtube videos on how to do this, shouldn't be too difficult if you take your time.
Also recommend getting OEM blacked out emblems for better quality and a nicer finish.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
How hard is too hard? coconutboy BRZ First-Gen (2012+) — General Topics 15 06-29-2019 01:36 PM
Is it REALLY this Hard ? Cosa Scion FR-S / Toyota 86 GT86 General Forum 40 10-13-2018 02:44 PM
Car jerking hard at WOT bryan.catano93 Forced Induction 64 06-22-2018 09:30 PM
How hard is it really? Kimsey47 Issues | Warranty | Recalls / TSB 13 08-16-2013 11:01 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
