Old 04-18-2021, 04:14 PM   #1
Andrewkd
Drives: 2017 Yellow series
Blown Amp Fuse after installing aftermarket HU
Hey guys, i recently installed a kenwood DMX4707S along with a metra harness and a autoharnesshouse 28 pin kit, after installing everything worked but the door speakers, I found that the amp fuse was blown... Any idea why? And what should I do to prevent it from blowing another fuse.
Thank you!
Andrewkd is offline   Reply With Quote
Old 04-18-2021, 05:03 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
it didn't like you touching precious.
if it keeps blowing you've got a wiring problem. if it doesn't, you messed up while installing it and didn't notice.
Old 04-18-2021, 10:39 PM   #3
Andrewkd
Haha that made me LOL
Yeah it's very odd that it blew up bot I will replace it, any idea what to do if it happens again?
Old 04-18-2021, 11:45 PM   #4
soundman98
soundman98's Avatar
i always reinspect the part that changed. first step is to return to the stock radio, and make sure nothing changed, then inspect the adapter harness for likely miswiring. optionally, try a different aftermarket radio to confirm a miswiring(same final problem, different known-good radio, just in case the one you've got is a dud)-- but that should be a last resort, as most people don't have extra aftermarket radios laying around, and they rarely do anything that would cause fuses to blow.
Old 04-21-2021, 01:53 AM   #5
Andrewkd
i replaced the fuse and it didnt blow up, but still have no audio from door speakers... really odd
Old 04-21-2021, 10:17 PM   #6
soundman98
soundman98's Avatar
did the remote turnon wire get connected to the new radio? i believe there's 2 of them. one in the speaker harness, and one in the radio power harness.
Issues installing aftermarket rear sway bar end links 3k1n Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-10-2020 05:15 PM
Code P2102 after blown fuse on battery terminal Krewmaui Engine, Exhaust, Transmission 1 05-05-2017 11:41 PM
Installing a aftermarket exhaut PECEOUT Issues | Warranty | Recalls / TSB 7 03-17-2017 09:32 AM
Noticeable vibration after installing aftermarket parts. boredjester Engine, Exhaust, Transmission 14 09-28-2016 10:38 AM
Power Outlet in Center Console not Working (Not a Blown Fuse) DemonRawr Issues | Warranty | Recalls / TSB 3 06-06-2016 04:14 PM
