Old 04-17-2021, 01:29 PM   #1
Jinxy86
Drives: 2019 86 TRD SE
Angry Toyota 86 TRDSE Rotor Question
I hope I've understood the rules and am posting in proper forum!
I just had my 50k inspection done and it called for new brake fluid, new pads, oil change and alignment.
Now my flippin brakes do not work. They pulsate when I stop and the rear brakes are squealing. I took it back to the dealership and the tech is intimating that I may need new rotors. All 50k miles are highway and I have never raced the car. This is hogwash yes?
Thx for any insight,
Newbie
Jinxy86 is offline   Reply With Quote
Old 04-17-2021, 02:14 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Did you bed them in?
Always ask to see the parts(pads in this case) they remove from the car. No way should you have needed pads at 50K unless you are driving two footed.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (04-17-2021), Spuds (04-18-2021), Tcoat (04-17-2021)
Old 04-17-2021, 04:48 PM   #3
Jinxy86
Thank you for the reply. I did not bed them in ugh.
Old 04-18-2021, 07:16 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
+1 to bedding the brakes in. Just be careful if it's not behaving consistently. A few good heat cycles should fix the problem, but it's going to be inconsistent at the start.
Old 04-19-2021, 05:15 PM   #5
jflogerzi
jflogerzi's Avatar
Rotors are cheap and anytime I change pads I change rotors. You don't have PP brakes?
2013 Series 10 FRS #553
Old 04-19-2021, 05:26 PM   #6
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
My front pads were done-zo at 50k. Winmax W3's and SS lines all around.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 04-19-2021, 05:27 PM   #7
spike021
spike021's Avatar
Those should be the PP brakes.
The pads do wear quicker than regular brake pads, I think. (mine got down to like 35% in roughly... 25k miles? but I did a track day, an autox, and also other fun driving)
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 04-19-2021, 05:40 PM   #8
jflogerzi
jflogerzi's Avatar
yup if its the PP then I would do the new rotors. You want the pads to have a nice new rotor to bed into anyways. The Pulsating leads me to believe the rotors have deposits on them or have un-even wear.
The Following User Says Thank You to jflogerzi For This Useful Post:
spike021 (04-19-2021)
Old 04-19-2021, 05:59 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is surprising, I know my co-worker got close to 100K mostly highway driving. I think he had ST street pads all the way around and did a couple track days with me.
I am not going to compare my usage lol
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 04-22-2021, 05:20 PM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Check the rear rotors and see if you have any white or blue spots on the rotor. What happened to me once was I had my 36K service done, they did my brake fluid and adjusted my parking brake, it was adjusted incorrectly and it was dragging causing a vibration and then eventually creating blue and white spots on the rotor.
N1rve
Old 04-22-2021, 06:29 PM   #11
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Newbie
Did they inspect, measure and resurface the rotors if there's enough there to allow doing so, on a brake lathe like they're supposed to whenever they change pads? Or did they half-ass it like most dealers do and just change the pads out?
Just for your information, I've had great results using Akebono pads in my work vehicle and my 20 year-old Solara and using OEM rotors. Aftermarket replacement rotors just don't hold up to the heat and end up warping prematurely.
Haven't had to touch the brakes on my twin since I got her.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
brakes, rotors, trdse
08+ STI rear Brembo caliper and rotor question Teratorry Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-20-2020 02:42 AM
Toyota 860 owners question. Terruko Scion FR-S / Toyota 86 GT86 General Forum 15 07-20-2018 10:07 AM
2017 Toyota Headlight modification question rcmf5525 Cosmetic Modification (Interior/Exterior/Lighting) 1 05-19-2018 04:20 PM
Question: Is Rebadge Legal (Toyota emblem on FR-S) Figo Scion FR-S / Toyota 86 GT86 General Forum 98 09-28-2016 12:26 AM
toyota/scion service question jarviz Scion FR-S / Toyota 86 GT86 General Forum 13 09-12-2012 09:56 AM
