Old 09-16-2020, 06:14 PM   #1
Teratorry
Teratorry's Avatar
08+ STI rear Brembo caliper and rotor question
Finally getting around to changing the rear calipers out for Brembo ones to match the fronts (CTSV Brembo Kit). I know that 08+ STI rear calipers are a direct bolt on to the BRZ hub, but I wanted to explore options for the rear rotors. I've seen a couple threads where STI rotors are redrilled to 5x100, but would the OEM performance package rear rotors from 17+ cars be a viable option or are they too small? Thanks for any input.
Teratorry is offline   Reply With Quote
The Following User Says Thank You to Teratorry For This Useful Post:
Joveen (09-16-2020)
Old 09-16-2020, 07:03 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Faction fab makes a rotor that is both 5x100 and 5x114.3
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 09-16-2020, 07:21 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
From a quick search I believe the standard rear rotor is 290mm and the PP rear rotor is 316mm. No idea how that would fit in your application.
Old 09-16-2020, 07:37 PM   #4
TwinFTW
Drives: 17 BRZ w/PP & 08 STI
As the owner of a 2008 STI I can tell you the specs on the rear rotor as I just replaced them last month
here are the specs:
Rotor Diameter: 316mm (12.44")
Rotor Height: 63.5mm (2.5")
Nominal Thickness: 20mm (0.787")
Minimum Thickness: 18mm (0.709")
Lug Holes Quantity: 5
Lug Holes Size: 12.8mm (0.5")
Bolt Circle: 114.3mm (4.5")
Hub Hole Diameter: 58mm (2.28")
The Centric part number is 125.47030
TwinFTW is offline   Reply With Quote
Old 09-19-2020, 07:21 AM   #5
will300
will300's Avatar
Drives: Subaru BRZ SE Lux
The centric part number you want is: 125.47043, this is the PP specific rotor, with the correct bolt circle: 5x100
The one TwinFTW listed is for 5x114.
Another option is from DBA rotors, the part number is: DBA 42656-10, these are dual drilled though.
My Build Thread - Subaru BRZ with ACE CS400 Header, Rogue Motorsport 2.5" Exhaust (Front Pipe & Catback), Tein Flex A, AP Racing BBK and 949 Racing 6UL Wheels.
will300 is offline   Reply With Quote
Old 09-20-2020, 02:42 AM   #6
jflogerzi
jflogerzi's Avatar
Carid and Rock Auto are the only places I could fine these PP rotors without paying an arm and a leg for the oem ones
2013 Series 10 FRS #553
Brembo BM-4 caliper Randoman5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 07-18-2024 09:45 PM
Oem Brembo Front/Rear caliper mount torque spec sroby Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-24-2020 05:23 AM
FS: Brembo Rear Brake + Stoptech Slot Rotor Sold(local pick up /Ship fee) andy86 Brakes, Suspension, Chassis 10 02-26-2018 03:10 PM
WTB: Rear Brembo STI caliper. grostoine Want-To-Buy Requests 2 07-16-2014 05:26 PM
