Howdy
Drives: 2020 BRZ PP
Howdy, I am looking for a front lip to put on the Berz and the drop I have feels around 40-50mm. The height is just about perfect that I will not bottom out unless it is very uneven; for instance I back out of my driveway, rather than pull forward, but so far this is the only rough spot.
I would really like to add a thin front lip, but from photos I have seen, they look to add about a half-three quarters inch to the front, once installed. Does anyone have a recommendation for a very thin front lip? I am looking for about a quarter-inch in thickness; it can be wide and that is fine. Thank you!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
Drives: Crapcan
Any of the STI or knock off STI lip kits will likely work for what you need. Most of the lip kits mount pretty tight to the factory front end. Really it is how far something like a real splitter sticks out that causes it to scrap.
spcmafia's car can be seen with a lip kit here. https://www.ft86club.com/forums/showthread.php?t=144409 If you look at the pics for the sti lip you can see how thin it actually is at the bottom as it essentially hugs the stock front end. https://www.subispeed.com/part/stie2...E#.YG9FxuhKiUk
#3 | |
Howdy
Drives: 2020 BRZ PP
#4 | |
Drives: 2018 Subaru BRZ
Stop, you're making me blush.
#5 | |
Check out Bayson R, they have lots of products for cheap, but good quality. Get some double sided tape (Optional). My whole lip kit was purchased from them and it fits like a glove. With the front lip you'll want to tape the lip to the front bumper to guide yourself drilling the holes underneath the bumper. Kit comes with self-tapping screws so all you need is tape and drill. If you want to go the extra mile, lightly sand and paint, leave under the sun prior to installation to ease fitting, I didn't need to with mine.
| Stock pad thickness | wparsons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-04-2022 09:54 PM |
| MAX Spacer thickness for stock studs? | FRSpdDmn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-09-2016 01:02 PM |
| Minimum HPDE Brake Pad Thickness | DarkSunrise | Tracking / Autocross / HPDE / Drifting | 11 | 10-28-2014 10:26 PM |
| Paint Thickness Measurements, Galaxy Blue | Nourdmrolnmt1 | BRZ First-Gen (2012+) — General Topics | 20 | 04-18-2013 03:48 PM |
| What thickness are the TRD swaybars? | jehu | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-06-2012 10:46 AM |
