Old 03-04-2021, 09:02 AM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
spcmafia's 18 BRZ XA Build
Updated parts as of 3/31/26. This is a dedicated SCCA-DST build.
Current Mods:
Engine Bay/Exhaust
  • K&N Drop In Filter
  • Perrin Inlet Hose
  • Raceseng Lightweight Pulleys
  • RacerX Catch Can
  • Verus Engineering Brake Brace
  • JDL Catted UEL Headers (Ceramic Coated)
  • OFT Custome Tune by Steve99
  • ARK GRIP Catback Exhaust with Torque Solutions Hangers set.
  • Odyssey AGM28L Battery
  • STi Engine Mounts
Transmission:
  • STi Transmission Mount
  • VERUS Pivot
  • Revised TOB
Suspension
  • RCE Tarmac 2s with Vorshlag Front camber Plates and Rear Hats
  • Whiteline Rear Adjustable End Links
  • Whiteline Adjustable LCAs
  • PERRIN 22mm Front Swaybar (Position 1)
  • Perrin Front Poly End Links
  • Whiteline Subframe Inserts
  • Whiteline LSD Inserts
Wheels and Tires
  • Konig Ampliform 17x9 +45s
  • ADVAN AO52s
  • ARP Studs
  • 949 Racing lug nuts
Interior:
  • Sparco EVO XL Seat on PCI Rails
  • Schroth Rallye 3 Harness
  • Raceseng Weighted shiftknob
  • HKS Steering Wheel hks51999-AT004
  • CUSCO Brake Pedal with custom gas and clutch aluminum pedals.
Alignment Settings (Autocross)
  • Rear: -3.5 Camber. 0 Toe
  • Front: -2.8 Camber. 0 Toe
Winter Alignment w/ Bridgestone Potenza RE980AS+ 225/45/R17
  • Front : -2.5 - 0 Toe
  • Rear: -2.00 - 0 Toe
Maintenance. Vehicle Purchased with 13,000 Miles.
  • 13K Miles: Oil Change (Motul 0w-20, OEM Filter)
  • 19K Miles: Oil Change (Motul 0W-20, OEM Filter)
  • 26K Miles: Oil Change (Motul 0W-20, OEM Filter).
  • 31K Miles: Oil Change, OEM Filter with Castrol Edge 0W-20 Full Synthetic, and Tire Rotation.
  • 37K Miles: Oil Change, OEM Filter with Castrol Edge 0w-20 Full Synthetic.
  • 43K Miles: Oil Change, K&N Filter with AMSOIL 0W-20 Full Synthetic.
  • 46K Miles: Transmission and Differential Oil, going with AMSOIL for both.
  • 50K Miles: Engine Oil Change, MOTUL 0W-20, OEM Filter.
  • 50K to 67K Miles: As of 6/9/2025. Changed Transmission and LSD fluids at 67K miles with AMSOIL. Engine has seen a combination of AMSOIL and SHELL Ultra Platinum 0W-20.
  • Oil Change done at 76000 miles. Penzoil Ultra Platinum 0W-20
Old 03-04-2021, 09:04 AM   #2
spcmafia
spcmafia's Avatar
The next project is looking like better wheels and tires. Very excited about tracking the car at least one time. Originally my goal was to just showcase the car since, remember, you don't track the daily.
Old 03-04-2021, 09:52 AM   #3
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Pics or it never happened!
Dzmitry is offline   Reply With Quote
Old 03-04-2021, 10:17 AM   #4
spcmafia
spcmafia's Avatar
Oh crap. my bad, here!
There's also a closer look on my IG page :https://www.instagram.com/shrapnellbranches/?hl=cs
Old 03-04-2021, 11:45 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Very pretty
MS, CSCS, TSAC-F, CPT
Old 03-04-2021, 12:53 PM   #6
spcmafia
spcmafia's Avatar
Originally Posted by weederr33 View Post
Very pretty
Thanks man!
Old 03-04-2021, 01:52 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Super clean looking despite the monster truck wheel gaps.
This is why I don't have a build thread, my car is a shitbox.
Old 03-04-2021, 02:21 PM   #8
spcmafia
spcmafia's Avatar
Don't remind me about those gaps haha. I don't think I could lower that car anymore because of how awful roads are where I live. I settled with at least having the tires flush to the body lines with the spacers.
Old 03-04-2021, 03:10 PM   #9
Purist
Purist's Avatar
Drives: Subaru BRZ
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 03-12-2021, 07:06 PM   #10
SuperSub7
Drives: Awesome
that is straight up gorgeous there!
SuperSub7 is offline   Reply With Quote
Old 03-12-2021, 07:12 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The timing of this comment is so poor.
Old 03-12-2021, 07:43 PM   #12
spcmafia
spcmafia's Avatar
Old 03-15-2021, 12:47 PM   #13
spcmafia
spcmafia's Avatar
I feel is only right to report this on the journal because I consider myself an honest person. I'm using this journal as a tool to record every modification/event this vehicle has partaken into for future plans such as a sale. Friday, March 12, 2021, my vehicle was damaged by a truck on the parking lot of my workplace. As what you can see on the photos below, the damage was pretty much the front bumper cover, with a small indent on the driver side front fender. The guy and his truck managed to clip the bumper just right with what I assume is tire or rear sensors, ripping the whole front bumper assembly. It can also be observed that the structural integrity of the car was untouched, by this I mean the front bash bar and frame. These vehicles have a fitting issue with the front bumper, so if anything, this comes as a blessing in disguise since a new bumper will mean new bumper clips and all pieces involved. Is just one of those things that as much as it sucks, at least it can be considered that things could've been much worse. I will update once the vehicle is out of the shop.
Old 03-18-2021, 12:43 PM   #14
spcmafia
spcmafia's Avatar
Initial estimate just came in. Should have the vehicle back on 3-25-2021. Came to about $1600 in repairs. Front Bumper is getting replaced, Driver side markers, and driver side front fender. I'm hoping the shop can salvage my front lip, even thought it's cheap, it's a pain to install and I'm not looking forward to that again.
