Old 04-04-2021, 10:03 PM   #1
pro_turbo
Drives:
Whag sensor for supercharged FA20
Hey guys.. i want to know what you guys think for me to add sensor to my FA20 for running supercharged engine with standalone.
Im thinking oil temp , oil press, and fuel press (secondary)
What about that ?
pro_turbo is offline   Reply With Quote
Old 04-04-2021, 10:55 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What are you monitoring through your standalone?
Are you asking about sensors, or gauges that display data from sensors?
What use are you driving the car under (track, daily, weekend warrior, etc)?
Oil pressure is your engine's lifeline.
Fuel pressure is also a lifeline
What can you monitor and react to fast enough where you're actually avoiding damage? I would focus on letting the ECU monitor and building fail-safes that react faster than you.
Oil pressure is good to watch on a gauge. Most everything else can be managed by your ECU unless you like watching
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 04-05-2021, 01:01 AM   #3
pro_turbo
Drives:
mostly weekend warrior
and yes that is the point i am asking
i want to make a fail safe map limit compensation with the sensors
i was wondering wether the secondary fuel pressure needs to read or just leave it stock to avoid leak in the future
but oil press and temp are a must for me
the secondary injector fuel pressure share the same pressure as the main fuel pressure or not ?
because we got the primary fuel press sensor from factory and it reads arround 10-15MPA
Old 04-09-2021, 03:21 PM   #4
pro_turbo
Drives:
No one here
Old 04-09-2021, 04:30 PM   #5
DarkPira7e
DarkPira7e's Avatar
In over my head, I'll leave that stuff to the real guys. It definitely can be done with custom maps in ECUtek, but you're going to need to be really on-point if you're expecting it to save your engine from damage. Hopefully someone here can answer thoroughly
What header are you running/ supercharged fa20's only Epic_integra Engine, Exhaust, Transmission 15 03-30-2019 01:57 AM
Whag is the newest ROM supported / Idle Issues Eazy-V Software Tuning 11 05-28-2018 04:36 AM
function of oil temp sensor on fa20? jcw99 Engine, Exhaust, Transmission 8 08-08-2016 09:42 PM
FBM 4-Bar Map sensor FA20 Scion FRS, BRZ , GT86 FullBlown Forced Induction 1 05-13-2015 04:38 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
