Because compromise ®
Drives: Red Herring
Oil Pressure Sender Unit Fitment Question
I am contemplating fitting a T piece/3 way junction between the the male fitting on the filter plate and the female fitting on the hose so I can mount a sender unit in the oil line to (or from) the cooler. That is, between the the parts indicated by the arrows. Do you think that the T piece would handle the vibration from the engine and the torque the hose would place on it?
Is there a reason why you would not use the port on the block for it instead?
I dont see how you would get an accurate reading from the send or return lines when thermostat is not fully open?
Drives: Red Herring
There is insufficient room to use the port on the block. I am hypothesising that the thermostat would only have to be fractionally open before you would get a pressure reading. That is, one is reading pressure not flow. Even so, I am not concerned with oil pressure readings before the engine has reached operating temperature.
| ???New Wheel Fitment Question!??! | 619_FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-03-2013 12:44 PM |
| new rim/tire. question about bolts pressure? and etc | WATCHMEHEAL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-25-2013 05:59 PM |
| fitment question | DanoFA20 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-16-2013 01:25 PM |
| Wheel fitment question | thelegaCy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-05-2012 11:22 PM |
| Fitment question for XXR 527 | ooharloo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-04-2012 09:35 PM |
