30 minute maintenance
Drives: My18 wrxsti
Crush washers?
Are the Gear box and diff crush washers the same part as the engine sump plug. I`m about to change the fluids and I have 1/2 a dozen engine washers. I wont buy new ones if they fit.
Persona Non Grata
Drives: '15 BRZ (WRB)
The diff and trans are the same size - 18mm x 24mm. I have a Fumoto drain valve and have forgotten the thread size, but I'm 99% sure it's not 18mm.
I picked up a selection of copper sealing washers from Amazon and used 4 of them - 1 for each drain and fill. The copper washers are potentially reuseable but they're cheap enough that I don't plan to. If you decided to reuse remember that copper work hardens and will need periodic annealing.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | gen3v8 (04-03-2021) |
Drives: 17 Asphalt 86
When I went to the dealer I ended up getting two different sets of washers for the trans and diff. They looked similar, but we're different part number.
| The Following User Says Thank You to RToyo86 For This Useful Post: | gen3v8 (04-03-2021) |
Drives: My18 wrxsti
Thanks Guys. I just measured the Engine sump washer and its Approximately 20 x 26. Copper is good and just heat to a glow and cool for annealing.
| 6 OEM black Oil filters + Crush washers | x_hawker | Mechanical Maintenance and Tools | 0 | 02-28-2021 11:33 PM |
| Are the differential crush washers the same? | givemeporknow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 02-16-2020 01:16 AM |
| FS: P/N 15208AA12A (3ea) Oil Filters & Crush Washers | zeal86 | Engine, Exhaust, Bolt-Ons | 8 | 10-24-2018 12:27 AM |
| Crush washers OEM vs Belmetric or other | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-03-2017 10:02 PM |
| Can the transmission crush washers be reused? | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 04-15-2013 08:35 PM |
