Old 03-29-2021, 08:11 AM   #1
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
NVH Questions
While I'm saving up for the dozen or so mods I have planned, I'm tinkering with making the car a smidge quieter/more refined. Along those lines, I'm doing some mild sound suppression. Two questions:
1. Does anybody have a trick for isolating the source of a buzz/rattle/other NVH? I have one somewhere around the steering column or instrument cluster area (resonance/speed sensitive, seems to be prevalent about 75-80mph?), but can't narrow down what it is.
2. Where do y'all buy Thinsulate Acoustic? I'd like to throw some in the door panels and rear wheel wells, but haven't found a good source outside of one sorta sketchy listing on eBay.
Thanks!
Cephas is offline   Reply With Quote
Old 03-29-2021, 09:22 AM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
If you haven't already found them, these threads may be of interest:
https://www.ft86club.com/forums/showthread.php?t=53511
https://www.ft86club.com/forums/showthread.php?t=35604
Get a mechanics stethoscope (the two-to-one single tube variety) and a small funnel that will fit into the end of the single tube. Might even want to get a little longer piece of tubing. This works great for finding the general location of a rattle. Pull out the funnel and use just the open end of the tube to narrow down the location of a rattle.
If you have automatic climate control (which an 860SE does) there is a cabin temp sensor in the dash by your right knee (assuming left hand drive). Looks like maybe three(?) slots in the dash plastic. Check the connector/wiring behind the sensor. Mine was buzzing as you describe. There are many other possibilities as well. They didn't spend much of the budget on NVH for this platform.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
Cephas (03-30-2021)
OFT v4 map questions ayau Software Tuning 1 09-18-2019 02:31 AM
OFT questions phantasticity Software Tuning 10 08-15-2016 10:18 PM
FRS/BRZ Questions, I am new. Reason22 FR-S / BRZ vs.... 14 08-14-2014 11:42 AM
BPU questions about what to get!! newports Engine, Exhaust, Transmission 39 07-18-2014 06:15 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
