Old 03-27-2021, 02:28 AM   #1
pro_turbo
Drives:
secondary fuel injector contribution
please someone help me to understand the secondary fuel injector table on the ecuflash or ecutek or romraider
by 0.3 is this means 30% secondary and 70% primary
thanks
pro_turbo is offline   Reply With Quote
Old 03-27-2021, 07:21 AM   #2
steve99
thanks
I think the tables your refering to are the port to direct injection ratio tables.
There are three cold warm and hot. Its best to keep same values in all 3 tables
The value in the table is the amount of port injection sometimes its a value between 0 and 1 and sometimes it might be a percent depending on which definitions your using.
so if tavle has 0.3 or 30% it means at that load rpm point ecu will use 30% port and 70% direct injection
Best nevercto put 1 or 100% in the tables as that means all port injection. This means no fuel through the direct injectprs which are in combustion chamber of engine. That would likely cause direct injectors seals to overheat and get damaged. You probably want not to go over say 0.7 to 0.8 or 70 to 80 % port injection so your always runnog a good amount of fuel through the direct injectprs
Old 03-27-2021, 09:20 AM   #3
pro_turbo
Drives:
My man..
Yeah it confirmed.. i just tried today on street
It was very torque full
I feel the pedal react to car move forward is better with pi table from the rom raider stage 1.
I think all the same through all stage rite
Even i have see the base ecutek map which is pretty the same .
If not mistaken the value is 0.3 in low and 0.2 at the max
The off in the middle of rpm
And back on 5000 rpm up.
Maybe you can share a stock ecutek table map
And i think there is treshold of they switching. By temp or something else. I forgot.
Well basically to translate from flash rom language to motec are really challenging.
But i am not giving up as i can feel better and better in everything i do into the engine.
fuel injector voltage toast Engine, Exhaust, Transmission 1 01-15-2019 11:56 AM
Fuel injector Service? HeadBanger CANADA 7 02-03-2016 10:52 PM
Fuel injector install xsnapshot Engine, Exhaust, Transmission 2 12-10-2015 12:17 AM
Dented fuel injector? pgranberg11 Engine, Exhaust, Transmission 7 07-14-2015 12:58 AM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
