| CANADA Canada |
Drives: '14 Subaru BRZ
Fuel injector Service?
Hey guys, not sure which section this belongs in, but I wanted to get opinions and experiences of fellow Canadians in particular anyways.
I'm approaching 60,000km. I called my "local" Subaru dealer to ask if they had any inspections they provide. When I worked at a Chrysler dealer we had what they called the Peace Of Mind Inspection. 30 point inspection, $29.95. We also had The Total Check-Up which was 100 some odd points. $89.95, which was essentially just an Ontario safety check. The woman I spoke to said at 60k we're due for a C Service, which among other things includes a fuel injector service. The cost of this service though is $650. I don't have that kind of money for a glorified oil change and fuel injector service. In essence I just want them to check the car out and change anything that needs to be changed under warranty. I know I have a leaky shock, so I'd rather Subaru pay for it. My real question here since I do all my own oil changes and regular maintenance is if anybody has done the fuel injector service or not. I don't notice any problems with the car right now, but I also don't want to void my warranty because I didn't do it. Have you done it at another garage? Here is the list of what to do at 60,000km according to the Subaru Canada website. Scheduled maintenance for 60,000 km / 36 Months Replace engine oil and filter Rotate tires Inspect tire condition and adjust all tire pressures including spare tire Remove, inspect and service front and rear brakes including parking brake Inspect and adjust all fluid levels including both differentials Inspect operation of all lights, wipers and washers Inspect and adjust drive belt tension if necessary Full battery service and test Inspect axle boot condition Lubricate all latches, hinges and locks (hood, doors, fuel door and trunk lid) Inspect all steering and suspension components Inspect under body for damage Test coolant, inspect hoses and clamps Inspect engine & air cabin filters - replace if necessary Replace brake fluid Service fuel injectors Inspect all emission-related hoses Inspect PCV valve - replace if necessary Road test vehicle
Life's too short to drive a boring car
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Very interested. I'm a couple K away from 60K too. Seems early for injector service. I wonder if that is more than a bottle of cleaner in the tank.
Sarcastic SOB
As I recall Subaru offered me that fuel injector service on my 2011 WRX as it approached 60K. They were charging $300 something 1 1/2 years ago. I ended up buying the car at 55K and trading the car at under 60K so never did it.
Supposedly they run 3 chemicals thru the fuel system, and there is a kit Subaru sells with three bottles of chemicals to do this. The difference is they have a machine they use to do the service. I am not sure how absolutely necessary this is if you use the best fuel, min 91 octane but perhaps it will clean out any gummy deposits that might exist. The other pricey service is fuel filter, which I think is at 100K. That service requires accessing in/around the fuel tank. I will most likely just go to a known Subaru (non-dealer) shop when the time comes. Using 94 exclusively, I am pretty confident my fuel system will stay clean pretty long. I might just replace the PCV valves myself on my 2 cars with FA20 engines when they're due.
#4 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I'm not concerned about the injectors being gummy. I only use Shell 91 (except that time I filled up two or three times in the states when I couldn't find a shell, but used mobile).
My concern is more for the warranty. If the motor were to ever go pop, I don't want them to say hey, you didn't do your injector service.
#6 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
At both thresholds, fuel injector cleaning was not brought up. I reckon it was at 96k though. |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I think these service "packets" are a money-grab.
I just had my service B done. $450 for a cabin air filter, oil and filter change, brake service, and inspection of major components. $450!!! Most of that is labour but that seems extravagant. I did it late, too. Supposed to be done around 30-40k. I did mine at 55k. So now I'm creeping up on this "Service C" you're speaking of, and there's no way in hell I'm shilling out ANOTHER $650 for basically nothing. My 3-year/60k already expired because of time, not mileage, anyways...
@bpennerz
Drift noob
Drives: 2015 BRZ Sport-Tech CWP 6MT
90% of the services on that list can be done by anyone who knows anything about car maintenance. I've never been denied any warranty claims for refusing to service my car at the dealer. Then again I've never blown an engine (that was under warranty that is).
FT86Z
藤原とうふ店 |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Fuel injector install | xsnapshot | Engine, Exhaust, Transmission | 2 | 12-10-2015 12:17 AM |
| Dented fuel injector? | pgranberg11 | Engine, Exhaust, Transmission | 7 | 07-14-2015 12:58 AM |
| Fuel injector cover | Notorious RBG | Engine, Exhaust, Transmission | 1 | 01-29-2015 08:14 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 06:54 AM |
