Old 03-26-2021, 12:36 PM   #1
pro_turbo
Drives:
Acceleration sensor
Is our car equipped with like evo yaw sensor
Or benz acceleration sensor ?
Thanks
pro_turbo is offline   Reply With Quote
Old 03-26-2021, 01:36 PM   #2
Ashikabi
Ashikabi's Avatar
I think the newer ones are
Old 03-26-2021, 01:45 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yes. It's all in the VSC module in the engine bay.
Old 03-27-2021, 10:31 AM   #4
pro_turbo
Drives:
You mean 17+ ???
Old 03-27-2021, 10:31 AM   #5
pro_turbo
Drives:
I never knew that.
Do you have the wiring diagram for that module ?
Old 03-27-2021, 10:58 AM   #6
Ashikabi
Ashikabi's Avatar
Originally Posted by pro_turbo View Post
You mean 17+ ???
Yes because I thought you could display that info on your dash
Old 03-27-2021, 11:03 AM   #7
pro_turbo
Drives:
Mine is 2013.
What info on the new dash ?
Accel display ? Never see on any car
Old 03-27-2021, 12:54 PM   #8
Ashikabi
Ashikabi's Avatar
Mine is 2013.
I thought the facelift models had a digital dash that could display yaw Gs and other data
Old 03-27-2021, 01:30 PM   #9
Yoshoobaroo
TRACKBREAD
I never knew that.
No, but from what I've been able to figure out researching the track mode retrofit, it's a self contained VSC computer with the accelerometer and IMU (gyro) built in. The ABS wheel speed sensors get fed into it and it controls the coils for the valves in the ABS pump.
Yes. It may work with a 2013-2016 VSC module too, assuming you have the facelift cluster.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Ultramaroon (03-27-2021)
Old 03-27-2021, 04:15 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah. VSC unit = ABS unit... Proprietary (closed) system designed and built to spec.
thomasmryan (03-27-2021)
Old 03-27-2021, 06:27 PM   #11
Ultramaroon
not playing cards
#righttorepair
Wally86 (03-29-2021)
Old 03-27-2021, 06:56 PM   #12
Lantanafrs2
Drives: 2013 frs red
#righttofuckupbecauseiknowmorethantoyota
Old 03-28-2021, 01:45 AM   #13
Ultramaroon
not playing cards
Are you shitting me? That's not how it works.
Lantanafrs2 (03-28-2021), Wally86 (03-29-2021)
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 04:32 PM
CEL,traction control and ABS sensor light up after I broke my Abs speed sensor? kuyumoy Issues | Warranty | Recalls / TSB 17 07-01-2018 09:24 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
