Old 03-26-2021, 01:21 AM   #1
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Tuned ECU from '13 into '16?
I want to move my AVO turbo engine from a '13 into a '16. I know the ECUs are the same part number between the cars.
After I swap the engine over -- moving the '16 coils and ignition harness to the '13 first -- can I use the tuned and locked ECU from the '13 in the '16?
Both cars are key start, so I assume I need to swap over the instrument cluster from the '13 to the '16 as well.
There is alot of time and money in this tune from Drift Office. Maybe I should just call them to see if they'll port it over for a nominal fee?
Thoughts?
Four_wheel_drifts is offline   Reply With Quote
Old 03-26-2021, 07:02 AM   #2
Ashikabi
Ashikabi's Avatar
Thoughts?
They might be the easier option but it'll likely cost you another license
Old 03-26-2021, 11:24 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
@steve99 would know.
On a side note, you need a hand getting that lava pulled apart?
Old 03-26-2021, 02:09 PM   #4
Four_wheel_drifts
Possibly. I am grateful for the offer.
What I really need is an inside space that is large enough to have both cars side by side for the swap.
I have a garage and a small shop. But both are full of vintage parts from other marques, sporting equipment, construction materials for home improvement projects, etc.
Old 03-26-2021, 02:23 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have the same issue. I got kicked out of working on stuff at my work since we are really busy and I won't be into my new place with shop until August.
Either way, just let me know. Would be happy to lend a hand.
Old 03-27-2021, 07:38 AM   #6
steve99
The 2013 ecu calibration will work fine in 2016 car, as long as both manual or both auto.
If you were using a 2016 ecu calibration in a 2013 car it would thow some cel code re dash and alternator.
but be fine a 13 ecu calibration in a 2016 car same transmission type doesnt matrer key or push start or if its brz 86 or frs
If your jist swapping ecu then you will need to use the ecu swap proceedure i posted here on the forum
but DO NOT change the vin number in ecu with ecutek licience in it you eill loose the ecutek licience. Just swap in ghe ecu and resync security the car doesnt care about the vin
Old 03-31-2021, 05:12 PM   #7
wparsons
wparsons's Avatar
If the region you live in does emissions tests plugged into the OBD port it'll check the VIN and validate it against the chassis VIN.
flickr
Old 04-02-2021, 01:59 AM   #8
steve99
we dont have reqular emmissions tests.
But i have heard some places in usa like Californa are very strict and check vin in ecu matches car
If its not an ecutek tuned ecu you can just change the vin with techstream and no issues, but ecutek keys licence to vin so you loose ecutek licience
Who tuned you (FI) yomny Software Tuning 7 02-23-2015 08:06 AM
My SWP BRZ: light tuned- stay tuned! Badaab Member's Car Journals 28 09-06-2013 12:35 AM
JR Tuned wrxgoose NY / NJ / CT / PA 4 05-22-2013 12:24 PM
FR-S E85 Tuned! Kochinopride Engine, Exhaust, Transmission 9 11-07-2012 02:29 AM
Used tuned 86! STJ Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2012 10:42 PM
