| Engine Swaps Discussion of engine swaps. |
Drives: Whiteout track car; lava donor
Tuned ECU from '13 into '16?
I want to move my AVO turbo engine from a '13 into a '16. I know the ECUs are the same part number between the cars.
After I swap the engine over -- moving the '16 coils and ignition harness to the '13 first -- can I use the tuned and locked ECU from the '13 in the '16? Both cars are key start, so I assume I need to swap over the instrument cluster from the '13 to the '16 as well. There is alot of time and money in this tune from Drift Office. Maybe I should just call them to see if they'll port it over for a nominal fee? Thoughts? |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#3 |
Drives: Crapcan
#4 | |
What I really need is an inside space that is large enough to have both cars side by side for the swap. I have a garage and a small shop. But both are full of vintage parts from other marques, sporting equipment, construction materials for home improvement projects, etc. |
#5 | |
Drives: Crapcan
Either way, just let me know. Would be happy to lend a hand.
#6 |
Drives: FT86
The 2013 ecu calibration will work fine in 2016 car, as long as both manual or both auto.
If you were using a 2016 ecu calibration in a 2013 car it would thow some cel code re dash and alternator. but be fine a 13 ecu calibration in a 2016 car same transmission type doesnt matrer key or push start or if its brz 86 or frs If your jist swapping ecu then you will need to use the ecu swap proceedure i posted here on the forum but DO NOT change the vin number in ecu with ecutek licience in it you eill loose the ecutek licience. Just swap in ghe ecu and resync security the car doesnt care about the vin |
#7 |
If the region you live in does emissions tests plugged into the OBD port it'll check the VIN and validate it against the chassis VIN.
#8 | |
Drives: FT86
But i have heard some places in usa like Californa are very strict and check vin in ecu matches car If its not an ecutek tuned ecu you can just change the vin with techstream and no issues, but ecutek keys licence to vin so you loose ecutek licience |
| Who tuned you (FI) | yomny | Software Tuning | 7 | 02-23-2015 08:06 AM |
| My SWP BRZ: light tuned- stay tuned! | Badaab | Member's Car Journals | 28 | 09-06-2013 12:35 AM |
| JR Tuned | wrxgoose | NY / NJ / CT / PA | 4 | 05-22-2013 12:24 PM |
| FR-S E85 Tuned! | Kochinopride | Engine, Exhaust, Transmission | 9 | 11-07-2012 02:29 AM |
| Used tuned 86! | STJ | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-02-2012 10:42 PM |
