Drives: '13 Toyobaru BRZ
SCCA Auto-x catalytic convert info
Hello everyone, Hope you're all having a fine friday. Im here today to ask about catalytic converters and the autocross rules applying to them for the street prepared class. I am simply wondering if I need to run a catalytic converter on both my headers and also the front pipe, or if I can get away with just one or the other.
Thank you all for your shared knowledge. Enjoy the spring roads, Drive safe!
2013 BRZ Premium
Injen short ram intake, OFT Stage2/e85 Ftspeed UEL headers, JDL front/overpipe, HKS high power dual outlet catback |
Drives: 2017 BRZ
I believe just the front pipe is ok. That certainly has been the case for years in STX and I believe the rule is shared here.
| The Following User Says Thank You to cjd For This Useful Post: | series420 (03-19-2021) |
Thank you very much for this info
2013 BRZ Premium
Drives: 2016 Brz Limited
STX requires that you keep one cat
"Any catalytic converters are allowed with the following constraints. Multiple catalytic converters may be replaced by a single unit. The inlet(s) of the replacement converter(s) must be located between the cylinder head and a point 6” (152.4 mm) further along the exhaust flow path from the original exit of the final OE converter." Street prepared allows for the removal of all cats. |
AutoX-10/10ths every run
Official rules can be found here: https://www.scca.com/downloads/53335...-book/download
| The Following User Says Thank You to whataboutbob For This Useful Post: | series420 (03-19-2021) |
#6 | |
2013 BRZ Premium
| The Following User Says Thank You to series420 For This Useful Post: | whataboutbob (03-19-2021) |
Drives: 2017 BRZ
Oh well then! I was too lazy to go double check.
Drives: Miata
What class?
#10 |
Drives: Miata
No cat required in street prepared.
| New Time: 86 Sessions Auto-X Day w/SCCA - Aug 21st | Locust | Northwest | 63 | 08-23-2016 11:00 AM |
| WNY SCCA Auto-x 9-1-13 & 9-22-13 Ralph Wilson Stadium | neurokinetik | NY / NJ / CT / PA | 3 | 09-18-2013 07:53 PM |
| SCCA novice Auto-X, April 20th @ PIR | BRZPDX | Northwest | 20 | 04-22-2013 01:06 AM |
| Any info from Detroit Auto Show? | Dorb | BRZ First-Gen (2012+) — General Topics | 18 | 01-28-2013 08:21 PM |
| 2013 Atlanta Auto Show Info | dirkXPC | Southeast | 2 | 01-09-2013 02:54 PM |
