Old 03-19-2021, 01:50 PM   #1
series420
Drives: '13 Toyobaru BRZ
SCCA Auto-x catalytic convert info
Hello everyone, Hope you're all having a fine friday. Im here today to ask about catalytic converters and the autocross rules applying to them for the street prepared class. I am simply wondering if I need to run a catalytic converter on both my headers and also the front pipe, or if I can get away with just one or the other.
Thank you all for your shared knowledge.
Enjoy the spring roads, Drive safe!
2013 BRZ Premium
Injen short ram intake, OFT Stage2/e85
Ftspeed UEL headers, JDL front/overpipe, HKS high power dual outlet catback
series420 is offline   Reply With Quote
Old 03-19-2021, 01:56 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
I believe just the front pipe is ok. That certainly has been the case for years in STX and I believe the rule is shared here.
The Following User Says Thank You to cjd For This Useful Post:
series420 (03-19-2021)
Old 03-19-2021, 03:43 PM   #3
series420
Thank you very much for this info
2013 BRZ Premium
Old 03-19-2021, 03:48 PM   #4
TeamBadger
Drives: 2016 Brz Limited
STX requires that you keep one cat
"Any catalytic converters are allowed with the following constraints. Multiple catalytic converters may be replaced by a single unit. The inlet(s) of the replacement converter(s) must be located between the cylinder head and a point 6” (152.4 mm) further along the exhaust flow path from the original exit of the final OE converter."
Street prepared allows for the removal of all cats.
TeamBadger is offline   Reply With Quote
The Following 2 Users Say Thank You to TeamBadger For This Useful Post:
series420 (03-19-2021), timurrrr (03-22-2021)
Old 03-19-2021, 04:14 PM   #5
whataboutbob
AutoX-10/10ths every run
Official rules can be found here: https://www.scca.com/downloads/53335...-book/download
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 03-19-2021, 04:47 PM   #6
series420
Originally Posted by whataboutbob View Post
Thank you guys
2013 BRZ Premium
The Following User Says Thank You to series420 For This Useful Post:
whataboutbob (03-19-2021)
Old 03-19-2021, 11:44 PM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
Oh well then! I was too lazy to go double check.
Old 03-20-2021, 09:57 AM   #8
racingfool
racingfool's Avatar
Drives: Miata
What class?
racingfool is offline   Reply With Quote
Old 03-20-2021, 04:28 PM   #9
whataboutbob
Originally Posted by racingfool View Post
What class?
It looks like SP from the original post.
Build thread:Here
Old 07-09-2021, 08:25 PM   #10
racingfool
racingfool's Avatar
Drives: Miata
No cat required in street prepared.
New Time: 86 Sessions Auto-X Day w/SCCA - Aug 21st Locust Northwest 63 08-23-2016 11:00 AM
WNY SCCA Auto-x 9-1-13 & 9-22-13 Ralph Wilson Stadium neurokinetik NY / NJ / CT / PA 3 09-18-2013 07:53 PM
SCCA novice Auto-X, April 20th @ PIR BRZPDX Northwest 20 04-22-2013 01:06 AM
Any info from Detroit Auto Show? Dorb BRZ First-Gen (2012+) — General Topics 18 01-28-2013 08:21 PM
2013 Atlanta Auto Show Info dirkXPC Southeast 2 01-09-2013 02:54 PM
