Drives: Widebody 86/F56 Mini Cooper S
Coilover Loose/Play
Hey so I've been dialing and experimenting with different ride heights over the past few weeks and decided I was gonna almost drop the rear to max. Did the right side rear to about 1.2 cm left and went to do the left side. It was originally on 2.4 cm and while lowering as soon as it got to 1.4cmish it started to become loose and have some play (the lower you go it gets looser), so for now I put it to 1.5 cm (still a tiny bit loose) and just put the wheel back on and lowered the car.
Here's a short clip of what I mean: Any ideas of what might be causing this? My first thought it maybe the top locking nut isn't tight enough but not entirely sure. I had a shop put the top nut cause I didn't have the right socket. They are Tein Street Advance Z Forgot to add, is there any harm in it having play or being loose? I would think it wouldn't matter much because the weight of the car would keep it stiff, but it's just odd it's happening to only one side. Last edited by Hamza; 03-06-2021 at 06:05 AM. Reason: Forgot a bit |
#2 | |
Drives: 2015 FRS
Preload and ride night are one in the same. Preload is when suspension is unloaded. Ride height is when loaded. Same adjustment nut just measured different. You are over adjusted. Put some preload back in. If you want to go lower you will need different springs.
Drives: Legacy 3.6R
Not true. Pre-load is how much compression is on the spring before the suspension is loaded, ride height is how elongated the overall strut is. MOST coilovers have separate adjustments and if you don't know what you're doing you should not touch the pre-load.
Drives: 2014 GT86
I'd word it differently. If one doesn't know what one's doing, better follow manual. Some coilovers may ship in state and their installation instructions may need setting first specific preload during installation. Not touching is not exactly best option in such case.
Drives: 24 GR Yaris, 23 GR86
Best coilover advice ever. Two things happened to me after doing this coilover rookie mistake myself: 1. Top hat camber bolts got loose and I got variable camber tophats
2. Preload adjusting collar somehow got loose and my passanger side started to make horrible clunking noise when hitting bigger bumps.
But again these don't have adjustable pre-load and I went lower on the other side with no play in the coil that's why im confused
What do you mean by 'overadjusted'? Also the other side is lower with no play in the coil, I was just trying to match this side as that but this one started moving a bit before I even got to the same height.
#10 |
Drives: Legacy 3.6R
If you mean that the spring is floating between the perches when unloaded this might be OK. I had lowering springs on my legacy where all 4 floated, granted not ideal... but I used them for a year before I switched to coils and they were "fine." (I was oversprung, but that had nothing to do with the float)
As for why you are lopsided my guess is a manufacturer defect. Did you buy them new? I'd call Tein. |
#11 |
Lots going on here.
1. Left and right differences are normal. Most cars do not weigh exactly the same for each side. 2. Your coilovers do have preload adjustment. The adjustable perch that the spring sits on adjusts preload. Preload also affects ride height. 3. You should pay attention to both preload and shock length when adjusting ride height. Preload for 1 set up may not work for every set up. 4. Many people and even many manufacturers simply do not understand spring preload. It's one of the most common coilover questions and it frequently gets many of the same wrong answers. Read this: https://www.instagram.com/p/B9J1M8Un..._web_copy_link ^That won't give you all the answers, but it will give an overview. I would recommend at least following Tein's recommendations for preload. |
#12 |
Yes but preload will affect right height. Preload and ride hight window is designed into the spring.
#13 | |
Remember just because it said it is adjustable does not allow you to get any ride hight. The strut/springs were designed for a window of adjustment, sounds like you are trying to go lower then they were designed for. |
#14 | ||
The fronts said a 2.6" drop and I've bottomed the front out all the way and it's still way higher than 2.6", but regardless the fronts are still stiff. My best guess now is still that the top locking nut on the strut isn't tight enough, kinda odd to tell because it's supposed to be hand tightened, and doing so every time I get scared of accidentally turning the dampening adjustment knob and breaking it (did that on the front). Can I tighten it with the strut still on the car with the car jacked up? |
| Loose axle | bmacfrs | Engine, Exhaust, Transmission | 0 | 06-05-2020 07:56 PM |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Coilover Preload collars keeps coming loose | BDotG | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-21-2015 10:23 PM |
| Loose A-pillar | ryoma | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-15-2015 05:00 PM |
| Loose Glove Box | Spd229 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-06-2012 01:53 PM |
