Old 02-26-2021, 04:41 PM   #1
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
Changing The Horn
Hey so I really dislike the stock horn. The car looks like a mean thing coming then makes a squeaking sound if you have to use the horn. Straight up my Mini makes a much deeper sound -_-
So my question was just is there anything about compatibility that I should look out for or can I just go to a scrap yard and pick out any horn and replace it? Was looking at getting an older 5 series horn because I've never heard a deeper horn than that. I assume it being Toyota it should be as easy as plug and play?
Hamza is offline   Reply With Quote
Old 02-26-2021, 05:39 PM   #2
sunami88
Drives: 2016 Hot Lava FR-S
You don't like the Road Runner!? The MEEP MEEP!?
I keep threatening to change the horn but I've been too lazy... I'm pretty sure the stock horn is just one (high) tone instead of the classic one high + one low... But changing it should just be plug and play as far as I know.
sunami88 is offline   Reply With Quote
Old 02-26-2021, 06:11 PM   #3
extrashaky
Drives: 2014 BRZ Limited
I have a full four note set of Cadillac horns I was planning to put on my Jeep, but maybe they should go on the BRZ instead.
Old 02-26-2021, 08:08 PM   #4
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
A couple people on the 86 FB group have train horns installed. Their videos when they get cut off are absolutely hilarious
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 02-26-2021, 08:12 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
hella supertones are a common mod.
but i've got an air horn i've been meaning to install. it gets more attention.
Old 02-26-2021, 08:41 PM   #6
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
BRZ Train Horn . . .
LimitedSlip is offline   Reply With Quote
Old 02-27-2021, 06:56 AM   #7
Hamza
Hamza's Avatar
I've looked at them, still not deep enough for how I want it haha we here flash and horn quite often and it's a societal trend sort of thing to have the brightest flash and growliest horn, it's basically asserts your dominance on the road
I just wanna know if the cables should just fit and work yk
Old 02-27-2021, 06:57 AM   #8
Hamza
Hamza's Avatar
A train horn would be hilarious but I'm tryna get something I can use, I just wanna know if the cables should just fit and work yk
Old 02-27-2021, 09:16 AM   #9
soundman98
soundman98's Avatar
Nothing is going to just fit and work. All of it is going to take some electrical work
Old 05-17-2024, 07:15 AM   #10
ukashaumar
ukashaumar's Avatar
Drives: bmw
I get your frustration with the stock horn—it can really kill the vibe of a badass car. Swapping out your horn sounds great, and I did something similar with my old truck. I found a sweet air horn at an auto shop. It was a bit of trial and error to install, but man, once it was in, it transformed the whole driving experience. Just make sure to check compatibility with your car model before diving into the scrap yard.
ukashaumar is offline   Reply With Quote
Old 05-17-2024, 04:36 PM   #11
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Your vehicle is really a Subaru, not a Toyota. Check out the YT vids for installing the Subaru Tribeca horns in other Subaru models. I installed the Hella Ferrari note horns in my FR-S.
tarzan_nojane is offline   Reply With Quote
Old 05-17-2024, 07:56 PM   #12
Dake
Dake's Avatar
I had a Wolo Bad Boy on my old Echo and it definitely upped the awareness factor. Simple plug and play. I haven't ever bothered looking into the FRS, but I thought the main issue is the horn is a nuisance to get to.
Dake is offline   Reply With Quote
NRG Hub/QR with Nardi Horn Michael Electronics | Audio | NAV | Infotainment 0 01-08-2017 12:21 PM
Changing the Horn? mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 21 10-27-2016 12:27 AM
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 03:50 AM
Mod that I never thought I'd want: a horn mike_ekim1024 Scion FR-S / Toyota 86 GT86 General Forum 46 02-03-2014 12:18 PM
Horn RedRocket Cosmetic Modification (Interior/Exterior/Lighting) 14 10-24-2012 11:26 AM
