Drives: Widebody 86/F56 Mini Cooper S
Changing The Horn
Hey so I really dislike the stock horn. The car looks like a mean thing coming then makes a squeaking sound if you have to use the horn. Straight up my Mini makes a much deeper sound -_-
So my question was just is there anything about compatibility that I should look out for or can I just go to a scrap yard and pick out any horn and replace it? Was looking at getting an older 5 series horn because I've never heard a deeper horn than that. I assume it being Toyota it should be as easy as plug and play? |
#2 |
Drives: 2016 Hot Lava FR-S
You don't like the Road Runner!? The MEEP MEEP!?
I keep threatening to change the horn but I've been too lazy... I'm pretty sure the stock horn is just one (high) tone instead of the classic one high + one low... But changing it should just be plug and play as far as I know. |
#3 |
Drives: 2014 BRZ Limited
I have a full four note set of Cadillac horns I was planning to put on my Jeep, but maybe they should go on the BRZ instead.
#4 |
Howdy
Drives: 2020 BRZ PP
A couple people on the 86 FB group have train horns installed. Their videos when they get cut off are absolutely hilarious
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#5 |
ProCrastinationConsultant
hella supertones are a common mod.
but i've got an air horn i've been meaning to install. it gets more attention.
#6 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
BRZ Train Horn . . .
#7 | |
I just wanna know if the cables should just fit and work yk |
#8 |
#9 |
Nothing is going to just fit and work. All of it is going to take some electrical work
#10 |
Drives: bmw
I get your frustration with the stock horn—it can really kill the vibe of a badass car. Swapping out your horn sounds great, and I did something similar with my old truck. I found a sweet air horn at an auto shop. It was a bit of trial and error to install, but man, once it was in, it transformed the whole driving experience. Just make sure to check compatibility with your car model before diving into the scrap yard.
#11 |
Drives: 2014 FR-S
Your vehicle is really a Subaru, not a Toyota. Check out the YT vids for installing the Subaru Tribeca horns in other Subaru models. I installed the Hella Ferrari note horns in my FR-S.
#12 |
I had a Wolo Bad Boy on my old Echo and it definitely upped the awareness factor. Simple plug and play. I haven't ever bothered looking into the FRS, but I thought the main issue is the horn is a nuisance to get to.
| NRG Hub/QR with Nardi Horn | Michael | Electronics | Audio | NAV | Infotainment | 0 | 01-08-2017 12:21 PM |
| Changing the Horn? | mechaghost | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 10-27-2016 12:27 AM |
| Consensus on changing whole transmission versus changing solenoids | dem00n | Engine, Exhaust, Transmission | 7 | 07-20-2016 03:50 AM |
| Mod that I never thought I'd want: a horn | mike_ekim1024 | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 02-03-2014 12:18 PM |
| Horn | RedRocket | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 10-24-2012 11:26 AM |
