Old 02-22-2021, 11:10 PM   #1
fatboydean
Drives: 2016 BRZ Hikari
Help!!! After installing Sony AX5000 my subwoofer barely works
Hi to all the masters and gurus here, just installed my Sony AX5000 myself on my 2016 BRZ Hikari Edition. Previous owner of the car installed a JL sub with built-in amp in the car. The sub's high level inputs were piggybacked to the factory amp's input. It's low level inputs, which are a pair of RCA connectors, were left unconnected.
Before installing the Sony HU, with stock HU I only need like 10% input sensitivity and it was really powerful and crisp. Now I switched to almost 100% and the sound from the sub is weak and muddy.
Yes I did make a mistake when connecting the factory amp remote wire, after I read in the forum it was corrected(pin 9 from the 10-pin connector). Now I have the factory amp working and door speakers working as well.
I never touched the sub's input circuit so it was unlikely to be a connection problem.
I also tried to connect the low level output from the Sony HU directly to the sub's low level RCA connections. It doesnt work I guess cos Sony HU low level output will not work if the amped outputs are connected? Is there any way to enable the low level output at the same time? I know there is a dedicated sub output, but my sub requires 2 RCA inputs, white and red(it has a low-pass filter), I tried the single output it did not work.
Although the sound quality increased a lot by the Sony HU, without the sub it's still not complete. I would like to make the sub work as well.
Please help! Thank you so much for reading this long post.
fatboydean is offline   Reply With Quote
Old 02-22-2021, 11:46 PM   #2
fatboydean
Angry
Just went to the car to take a closer look, my mistake, the sub high level input is tied to the factory amp output. Please see the attached pic. So its really 'high level' since its amped.
Since my door speakers works fine there is really no reason for the sub not working properly. Could it be the Sony HU's power output is lower than the stock HU? Mine is the Fujitsu TEN.
Could it be a bad car battery? I tested the sound system with the car engine running though.
I am offically running out of ideas...
Old 02-23-2021, 12:22 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
what model jl sub?
Old 02-23-2021, 12:36 AM   #4
fatboydean
what model jl sub?
Not sure the model but here's the pics of the sub
12V power supply, REM both checked n true.
High level input in the pic is tied to the factory amped output of front door speakers.
Old 02-23-2021, 12:51 AM   #5
soundman98
soundman98's Avatar
you can try to flip the output polarity switch to '0' instead of '180'
is your low pass frequency knob set to 50hz?
and you did connect the blue remote turn-on wire to the radio, right?
the rca jacks should work with one or the other(normally left side is the mono input). i've never heard of an amp that requires both to work.
i don't know enough about sony decks to know what their default configurations are.
Old 02-23-2021, 12:58 AM   #6
fatboydean
What value should I use for LP Freq?
Yes remote on also tested 12V so door speakers working fine.I will try again tomorrow to see if the mono input works on mine. I do need to disconnet the high level input first right? I tried using the sony's low level output to test but I got no signal at all, maybe because I was using the AMPed output already... not sure.
So if all those failed it means I broke the sub... right? Any other things I can try?
Old 02-23-2021, 10:47 PM   #7
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You can try reading the manual of your new Sony head unit for starters and understand how the low level outputs work. You may have to switch them on in the programming section first in order to get any signal output. Then realize that you can only use EITHER the high level speaker inputs for the sub amp OR the low level RCA inputs, but NOT BOTH.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 02-24-2021, 01:35 AM   #8
fatboydean
Thanks, I tried to use the sub output from the HU and yes it has a switch in the EQ menu, but mine sub requires 2 RCA and Sony only has one, I tried to use it as MONO but the sub did not respone at all. Next step would be to get a spliter and try it out. If still not working, I will give up and revert back to factory HU.
Old 02-24-2021, 09:10 AM   #9
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Splitting the signal SHOULD fix the problem IF the left and right inputs are required by the sub amp.
After doing that, take note of the subwoofer crossover setpoints in your Sony head unit. I see in the pictures you posted that you have your sub amp crossed over at 50 Hz. Try turning that up to 200 Hz and try to adjust the crossover frequency and slope settings inside your Sony, but get your levels correct first. Unfortunately, the factory amp does not have a gain control on it to allow level matching of the system so you may find that you can turn your new head units' volume control up only part way before running your door speakers into distortion. At that point you may find that you barely have enough low level subwoofer signal to the sub amp and will have to turn the level control up on the sub amp quite a bit to get any decent volume out of it.
My point is, in your system, the weak point is your factory amp due to its' lack of level matching capability.
Old 02-24-2021, 09:13 AM   #10
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
One other possibility is that when you connected the RCA output from the head unit to the sub amp with the high level inputs still connected, you could have fried the RCA output circuitry inside your new head unit.
Old 02-25-2021, 05:31 PM   #11
fatboydean
Oh that! I made sure it was disconnected!
Old 03-06-2021, 08:28 PM   #12
fatboydean
Update: I feel there isnt much difference in sound quality between the stock HU (door and dash speakers replaced by previous owner) and the Sony AX5000, plus the sub works better with stock HU. I decided to return the Sony HU and keep my stock setup. The sunk cost will be the dash kit, harness and the cables.
Thanks for all your suggestions.
Old 03-23-2021, 08:09 PM   #13
Shanahan
Shanahan's Avatar
Probably too late now but I will say it for anyone else that runs into this issue. I have the same Sony (not that’s it matters). The line levels with mix and match of stock amps and aftermarket on these systems make it a mess. I put the Sony in and a JL sub with Excellon amp. The sensitivity of the stock speakers with the higher output head unit make the stock speakers distort at less than 10% volume. The sub is hardly heard because normally at 10% you wouldn’t want it loud. You have to be able to level the outputs to make it sound good. My “throw the spare head unit in for a cheap fix” project turned into a full blown build.
Shanahan is offline   Reply With Quote
Old 03-24-2021, 01:19 AM   #14
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Just curious, how many speakers/amplifier channels are you running now?
Need help installing subwoofer with amp to oem HU and sound system (2016 FRS) Sonicp9 Electronics | Audio | NAV | Infotainment 15 08-12-2022 10:40 PM
FS: TRD Louvers barely used tawheed Exterior Parts (Aero, Lighting, Etc.) 4 03-12-2018 12:14 PM
Experience Installing the Works Stage 2 Turbo Kit Aussie Forced Induction 8 01-30-2018 12:59 PM
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 10:22 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 07:12 PM
