Old 01-25-2018, 09:08 PM   #1
Aussie
Drives: 2013 Scion FR-S 6MT
Experience Installing the Works Stage 2 Turbo Kit
I recently installed a Works Stage 2 Turbo Kit that used my existing OFT Flex Fuel System.
I am delighted with the results and wanted to share some of my experience with all those who are interested in this CARB compliant turbo kit. If you persevere watching all the videos you will see this was a driveway install that ended up with me requesting help from Works. That said they were brilliant and everything ended well.
I made some install videos but the one most people would be interested in is the dyno session to produce an Open Flash based flex fuel tune. Here are some links:
Last day dyno session
[ame="https://www.youtube.com/watch?v=AFxe8ZZR8X8"]https://www.youtube.com/watch?v=AFxe8ZZR8X8[/ame]
Day 1
[ame="https://www.youtube.com/watch?v=aqwci9gBVjo&t=1s"]https://www.youtube.com/watch?v=aqwci9gBVjo&t=1s[/ame]
Day 2
[ame="https://www.youtube.com/watch?v=E2sK3hs9TQI"]https://www.youtube.com/watch?v=E2sK3hs9TQI[/ame]
Day 3
[ame="https://www.youtube.com/watch?v=eqI9nZIn9w8&t=2s"]https://www.youtube.com/watch?v=eqI9nZIn9w8&t=2s[/ame]
Day 4
[ame="https://www.youtube.com/watch?v=94R53_Pu3v8&t=1s"]https://www.youtube.com/watch?v=94R53_Pu3v8&t=1s[/ame]
Day 5
[ame="https://www.youtube.com/watch?v=aHzUUXKcLms&t=3s"]https://www.youtube.com/watch?v=aHzUUXKcLms&t=3s[/ame]
Aussie is offline   Reply With Quote
The Following 3 Users Say Thank You to Aussie For This Useful Post:
DAEMANO (01-26-2018), gtengr (01-28-2018), Teseo (01-26-2018)
Old 01-26-2018, 01:02 PM   #2
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Great videos Rob! It was really great meeting you as well.
WORKS is offline   Reply With Quote
Old 01-26-2018, 01:11 PM   #3
DAEMANO
Time Traveller
I now may have a reason to keep my NIB OpenFlash Flex Fuel Kit. Great vids, thanks!
The Following User Says Thank You to DAEMANO For This Useful Post:
WORKS (01-26-2018)
Old 01-27-2018, 03:16 PM   #4
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Can't wait for you to finish this series of videos. So far its been very informative.
TachyonBomb is offline   Reply With Quote
Old 01-27-2018, 09:43 PM   #5
Aussie
The series is pretty much finished other than recording an impression after a month or so. Let me know if you have any questions.
Old 01-28-2018, 10:19 AM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
CARB compliant Works Turbo kit with non-CARB compliant FlexFuel kit with non-CARB compliant OpenFlash tune is a non-CARB compliant car... Just because someone may ask.
Old 01-29-2018, 03:17 AM   #7
TachyonBomb
My car is already there for a 2017+ kit so no real questions on my end.
Maybe an update on what the issue was and how the issue was solved.
In the future, I'll eventually be upgrading to a gtx2867 or gtx2967 which uses the T25 SR20 style 5-bolt exhaust compressor housing. So I'm curious as to why yours did not fit. There are 2 other people I know on here that have upgraded to gtx turbos which fit the works plumbing.
When I first saw your video I thought you may have been given a turbo with an RB26 style T25 5-bolt exhaust wheel housing. But there are a few times when you can pause the video just right and see that it is an SR20 style exhaust compressor housing. The skyline version would make your turbo sit slightly off but that theory is now out the window.
Old 01-29-2018, 02:29 PM   #8
Aussie
The turbo I have is a GT2860RS with the the T25 SR20 style 5-bolt exhaust compressor housing. It appears that the compressor housing is a little different from the original journal bearing turbo. This caused the compressor intake plumbing to end up too close to the strut tower. Works redesigned and installed a new up pipe to give more clearance.
The other issue was the waste gate actuator that was also too close to the strut tower. Here they added some spacers on the actuator bracket and clocked the compressor by a few degrees to make it all fit within spec.
Works were surprised by the issues I had because other people have installed similar turbos with no issues. They now have the information in house to make sure this issue is fixed.
The Following User Says Thank You to Aussie For This Useful Post:
TachyonBomb (01-30-2018)
Old 01-30-2018, 12:59 PM   #9
TachyonBomb
Very interesting!
The other guys running ball bearing turbos are GTX series turbos. Funny that the GT, GT(Ball Bearing) and GTX turbos were made to have such a slight difference in dimension. Either way this was a very well done series of videos with a very educational outcome.
The Following User Says Thank You to TachyonBomb For This Useful Post:
Aussie (01-30-2018)
WORKS Motorsports Turbo Kit Experience raven1231 Forced Induction 104 04-18-2025 03:24 PM
King Tut's Full Blown Motorsports Stage 1 Base Turbo Kit Experience King Tut Forced Induction 196 09-04-2016 09:47 AM
Experience with Works Stage 1 Turbo Kit aaguirre123 Forced Induction 33 09-18-2015 08:16 PM
My Experience with Works Stage 1 Turbo Kit aaguirre123 Member's Car Journals 9 06-09-2015 07:47 PM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
