Old 02-22-2021, 04:59 PM   #1
gpvecchi
gpvecchi's Avatar
Noise at idle
My 25000 km car started (or I just noticed it) a new noise: when cold, at idle i hear a clackclackclack noise. It goes away when I depress clutch.
Sometimes I got a small similar sound from the play of the TOB, but this one is much more strong.
Anyone please?
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
humfrz (02-23-2021)
Old 02-23-2021, 05:33 PM   #2
humfrz
Have you changed the transmission oil lately?
Has it been colder than usual?
Gear rollover maybe?
What say you, there, @Ultramaroon?
gpvecchi (02-24-2021), Ultramaroon (02-23-2021)
Old 02-23-2021, 10:05 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Audio clip?
Old 02-23-2021, 10:12 PM   #4
ermax
ermax's Avatar
TOBs failing can sound a bazillion different ways. I replaced mine with the new white dot version and it’s now on its way out. It sounds sort of like rod knock but if I put it in neutral and the let the clutch out it stops. It was making a screaming sound but that seems to have gone away now. Obviously it’s still on its way out, my point is it can sound a lot of different ways. The fact that this car eats TOBs (even the new style) and actuating the clutch makes the sound change, my bet is on it being your TOB.
The Following User Says Thank You to ermax For This Useful Post:
Old 02-23-2021, 11:05 PM   #5
tomm.brz
Drives: brz 2017 hksv2
same here
TOB and clutch chatter a lot on idle but then when clutch is pressed it becomes dead silent
I do have the newer one and it's failing too
The Following User Says Thank You to tomm.brz For This Useful Post:
Old 02-23-2021, 11:46 PM   #6
Ultramaroon
not playing cards
I guess it's always a good idea to drop the trans to replace the TOB and clean stuff. They do eat TOBs. There's also a little test to check each gear pair but one needs to be quick and gentle. Leave the clutch engaged and nudge the gearshift into each gate. Listen for any changes in sound as you load up each syncro clutch. If the clack can be felt, or the sound changes, you found it. Might get lucky.
Old 02-24-2021, 01:49 AM   #7
gpvecchi
gpvecchi's Avatar
I tried taking a video, but sound is too low. No recent changes except some degree hotter...
Old 02-24-2021, 04:49 PM   #8
gpvecchi
gpvecchi's Avatar
So strange, a friend has this problem since 2 days, exactly like me, this is the video he sent me:
https://www.facebook.com/messenger_m...eCSl309Isto8D1
Mine does it a little more, as I have LWF...
Old 02-25-2021, 04:23 AM   #9
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
That link doesn't seem to be working.
Is your issue the same as mine that I posted here a couple of days ago?
I started hearing a weird noise that I believe is coming from the transmission and it somewhat goes away when I put the clutch in. Here is a video of it:
Oxyg3n is offline   Reply With Quote
Old 02-25-2021, 05:09 AM   #10
tomm.brz
TOB/clutch chatter
as usual in this car for 9 years almost
You can whine about it and try to find expensive solutions, or just ignore it and keep change the TOB whenever you have the chance to do it as part of other jobs for example without overdoing as it s not necessary
Old 02-25-2021, 05:09 PM   #11
gpvecchi
gpvecchi's Avatar
Noise is like the same yes. TOB usually whines when pressed, as in many other threads, as it's not involved when cluch is depresssed.
This sounds more like gears noise IMO.
Stange is that 3 cars started all together 2 days ago...
Old 02-26-2021, 01:00 AM   #12
tomm.brz
Humidity plays a role, as it plays in high pressure fuel pump crickets with some quality of fuel
His sound goes away when clutch is pressed, so to me is TOB/clutch chatter and it's so common in this car that one shouldn't even suprise himself anymore
Old 02-26-2021, 01:57 AM   #13
gpvecchi
gpvecchi's Avatar
TOB chatter should stop if you put tension on it,slightly pressing the pedal, just to push the TOB against the spring, but not enough to disengage clutch. But the noise is still there, so it's gears for sure.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Idle knocking noise Kostamojen Issues | Warranty | Recalls / TSB 33 04-20-2018 02:09 PM
Ticking/Rattling noise at idle. Razgriz Issues | Warranty | Recalls / TSB 4 08-17-2017 10:02 PM
Noise when idle (not Crickets) hanabie Issues | Warranty | Recalls / TSB 8 10-18-2013 09:58 PM
Idle Sound Click/Noise FRS_Jack Issues | Warranty | Recalls / TSB 4 10-13-2013 10:26 PM
