Old 02-06-2021, 04:05 PM   #1
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Does Anybody Ever:
Follow the service manual and use new bolts and nuts where it specifies?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-06-2021, 04:44 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yes but not always. Depends on the application.
Old 02-06-2021, 06:29 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
depends entirely on whether i planned the job out in advance, or if new bolts can be delivered by tomorrow.
i've always re-used the copper drain plug crush washer...
Ohio Enthusiast (02-06-2021)
Old 02-07-2021, 04:26 AM   #4
JIM THEO
Drives: BRZ 2018
Usually...
JIM THEO is offline   Reply With Quote
Old 02-07-2021, 04:58 AM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Not on head bolts or snapped wheel studs
gen3v8 is offline   Reply With Quote
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
Capt Spaulding (02-07-2021), soundman98 (02-07-2021)
Old 02-07-2021, 12:10 PM   #6
Capt Spaulding
Persona Non Grata
I've seen a number of how-tos on a variety of mod procedures and I can't think of any of them that mentioned the fastener replacement issue. I swapped out my stabilizer bar bushings (front and rear) recently. At both ends, the FSM specifies new fasteners. The front subassembly uses eight 10mm (shank diameter) bolts that get torqued to 44 lb/ft, That seemed really low considering the number and size of the bolts. I reused. Similar with rears.
Over the years, I've generally seen the bolt replacement requirements in torque-to-yield situations. I've religiously applied the replacement rule in those cases. Other places like brake caliper bolts on roadracing motorcycles where the calipers are coming off and going on like neon signs - generally not. Subie seems to take the approach that "if you turn the bolt or nut, replace it." I chalk it up to litigation paranoia, but ... Thanks for the input.
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post:
humfrz (02-07-2021), Ohio Enthusiast (02-08-2021), Ultramaroon (02-07-2021)
Old 02-07-2021, 01:23 PM   #7
Ultramaroon
not playing cards
Sounds like you have ample experience to make appropriate decisions. You gots dis.
Old 02-07-2021, 11:24 PM   #8
humfrz
"Of course, iffen you are going to torque them down till they twist off, you would have to replace them - ".
(sorry folks, I told Bubba to stay away from my computer).
soundman98 (02-08-2021)
Old 02-08-2021, 12:08 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yes and no.
Depends on the situation
humfrz (02-08-2021)
Old 02-08-2021, 02:36 AM   #10
humfrz
Yes and no.
You planning and practicing on running for a political office?
gravitylover (02-10-2021)
Old 02-08-2021, 10:26 AM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
definitely maybe.
humfrz (02-08-2021)
Old 02-08-2021, 10:39 AM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Ho for HOA nosy parker!
Old 02-08-2021, 11:15 AM   #13
D20Z
Drives: 20 BRZ
Yes and especially under warranty.
D20Z is offline   Reply With Quote
Old 02-08-2021, 05:14 PM   #14
Yes, almost always.
