Drives: 2014 Subaru BRZ Limited MTblue
How much TOB travel req'd to disengage OE clutch?
I am looking for technical detail. OE clutch. Once the TOB contacts the clutch fingers, how much linear travel or movement is required to disengage the clutch?
MY14 |
Answered!!
I reached out to Exedy. About 8mm. Sent from my moto g power using Tapatalk |
Señor Member
Interesting but I have absolutely no idea what to do with this information.
1974 TA22 Celica
2013 86 GT |
#4 | |
I'll splain it
(maybe more info than you expected!) Well, I have a Hydraulic Release Bearing. (a Tilton cylinder) The bearing froze up and destroyed the cylinder. I resurfaced my flywheel and installed a new OE Exedy clutch. I needed to be sure that my new TOB had the proper clearance between it and the clutch fingers. The Tilton cylinder has a total movement of .7" . I measured the distance from the bellhousing/trans mounting surface (at engine block) to the clutch fingers and also to the TOB surface (fully retracted) I needed to alter the latter measurement to provide the clearance I wanted. I wanted to know how far the TOB needed to travel to fully disengage the clutch. That's the 8mm that Exedy told me. (I suppose I didn't need this number for sure, but it's nice to know.)Turns out that the cylinder has plenty of movement to allow the clearance I wanted. Tilton suggested .170" to .230" of clearance. I went with the minimum of .170" and added .200" to allow for clutch wear. I ended up machining my HRB base to get this clearance. (Still waiting on my machinist, though.) |
| Notches in clutch travel | alex87f | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 05-01-2019 12:47 AM |
| Clutch Pedal Travel Stopper (CPTS) Modification | JDKane527 | DIY (Do-It-Yourself) Guides | 35 | 01-26-2019 03:37 PM |
| Clutch Squeaks at the end of travel... clutch fork? | treminaor | Issues | Warranty | Recalls / TSB | 54 | 12-02-2016 03:53 AM |
| Is it possible for an AT to disengage from motor at idle? | ray7792 | BRZ First-Gen (2012+) — General Topics | 7 | 11-13-2014 08:00 PM |
| Clutch disengage whining sound? | Bach415 | Issues | Warranty | Recalls / TSB | 7 | 07-12-2013 07:52 PM |
