Old 04-29-2019, 06:47 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Notches in clutch travel
Hello guys,
I've noticed that my clutch pedal sometimes has light notches throughout its travel. It doesn't always do it and the clutch pedal may feel perfectly linear one throw, and notchy the next one.
The clutch fluid was just changed, though the car was already doing this before. I think it's become a little more obvious as the fluid change helped make the clutch lighter. TOB was changed 1.5 years / 20k ago as part of a cam plate repair (sic.). Car is a 2013 with 50k on the clock.
I've already had such issues on a previous car, which were caused by the clutch fork bushing having become contaminated with dirt / debris. Removing, cleaning and greasing it had solved the issue permanently. Has anyone attempted such a fix on the twins? And if yes would I be able to do this without bleeding the clutch? Is this a common issue?
Best regards,
Alex
alex87f is offline   Reply With Quote
Old 04-29-2019, 08:23 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well that sucks.
And yes some one out there did make a hydraulic replacement unit that does away with the TOB and fork.
Well my only guess is the clutch master cylinder is toast. Not sure if a replacement is worth the time and effort.
Old 04-29-2019, 08:27 AM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
@celek at Money Shift Racing makes the hydraulic TOB.
http://www.ft86club.com/forums/showt...ighlight=celek
BigTuna is offline   Reply With Quote
Old 04-29-2019, 09:19 AM   #4
ermax
ermax's Avatar
This is a common problem on all cars. If the dirt gets into the grease on the shaft or dries out then it’s going to feel notchy. You can try cleaning the fork externally and then reapply the grease but most likely you will need to drop the tranny and clean up the whole shaft. You will not need to bleed the system to do this job.
Another cause of a notchy feel could be pockets of air in the line cause by a bad master or slave. Is your fluid dark? If so then the rubber seals in the master or slave are going bad.
Old 04-29-2019, 09:26 AM   #5
alex87f
Meow
alex87f's Avatar
Originally Posted by Mr.ac View Post
Well that sucks.
How does one kill a master cylinder though? It's always had the proper fluid level, always used DOT4, etc.
The hydraulic TOB sure seems like a nice solution, but buying and installing will be $$$$. I was hoping to just clean the bellhousing bushing the fork rotates on, which would pretty much be a free repair. Basically the articulation point for this part:
Old 04-29-2019, 11:15 AM   #6
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
The notchiness (not sure if thats a word) of the pedal was happening after i adjusted the clutch pedal back to the stockish position. I adjusted it back to a low engagement point (clutch pedal about 2-5mm above the brake pedal) and havn't had the notchy crunchy feel in the pedal ever since. Definitely not a fix.
VenomRush is offline   Reply With Quote
Old 04-29-2019, 12:30 PM   #7
humfrz
Originally Posted by alex87f View Post
Hello guys,
I've noticed that my clutch pedal sometimes has light notches throughout its travel. Best regards,
Alex
Allow me to refer you to our clutch expert @Ultramaroon.
humfrz
Old 04-29-2019, 12:45 PM   #8
ermax
ermax's Avatar
Age. Rubber only lasts so long even if you’ve always used the correct fluid.
Old 04-29-2019, 12:47 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Might be a couple things.
  1. The TOB is self-centering by design. It floats in its housing but there's a tight spring behind it to make it sticky. Sometimes it gets off center and the wobble can be felt when depressing the clutch pedal. This is more obvious when...
  2. The snout/quill/front cover has worn to the point where the TOB begins to bind as it moves. A lip forms on the quill at the end of travel. If the clutch pedal is raised, the TOB is forced past that lip and the bind can be consistently felt with each operation.
Old 04-29-2019, 12:52 PM   #10
This was what happened later in my bearing failure. I would expect it to have started squealing before reaching this stage though.
Old 04-29-2019, 01:13 PM   #11
Ultramaroon
not playing cards
I feel it off and on all the time.
Old 04-29-2019, 01:18 PM   #12
Haven't noticed it in the 60,000 or so miles since it was replaced.
jcw99 (04-29-2019)
Old 04-29-2019, 06:31 PM   #13
gravitylover
The snout could be scored too. Mine was and they didn't replace it when they did the clutch they just cleaned it up with scotch brite and steel wool but it still had ridges on it and they put it back in and hoped for the best. 2 or 3 days after I got the car back I took it in because the clutch was notchy and not releasing completely all the time. downshifts got crunchy too. As soon as I explained what was going on they asked if I had a ride home It was a nice walk of ~2 miles. They replaced the snout, and TOB again just for good measure, and all has been well since and that was about 12k miles ago. By trying to save a few dollars on the part the first time they ended up having to drop the tranny again and do it over. I know they changed it because I had them save the old part for me.
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
humfrz (04-29-2019), Ultramaroon (04-29-2019)
Old 04-29-2019, 08:33 PM   #14
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I think i have this problem too.
While i the clutch was in traveling motions, it has this little knock or tick sound whatever u call it
IG: @rearwheelclub
FR-Sky is offline   Reply With Quote
Clutch Pedal Travel Stopper (CPTS) Modification JDKane527 DIY (Do-It-Yourself) Guides 35 01-26-2019 03:37 PM
Clutch Squeaks at the end of travel... clutch fork? treminaor Issues | Warranty | Recalls / TSB 54 12-02-2016 03:53 AM
when I go to great travel reinketrx Off-Topic Lounge [WARNING: NO POLITICS] 0 06-12-2016 06:26 AM
How To: BRZ infinite 1-5 headlamp adjustment(no more notches!) soundman98 DIY (Do-It-Yourself) Guides 7 01-27-2015 11:10 PM
