Old 01-08-2021, 06:28 PM   #1
spike021
spike021's Avatar
2017+ BRZ Foglight yellow LED assemblies
Lately I've been thinking about seeing if the fogs can be converted to yellow LED's.
After searching the forum a bit, I came across this thread and others that confirm 2017+ BRZ's have basically permanent fog light LED's as assemblies:
https://www.ft86club.com/forums/show....php?p=2941279
It seems they aren't meant to be swappable anymore.
I really don't love the idea of using tint film.
So, I'm curious. Does anyone know if any aftermarket companies have come up with replacement assemblies with yellow LED's?
If prohibitively expensive, then I wouldn't do it. But I'm definitely wondering if any companies have bothered touching this.
I guess the final, most expensive option is probably buying replacement assemblies myself and paying someone who's an electrician to crack them open and do the necessary de-soldering/re-soldering to switch the LED's. Definitely not ideal.
I can live with it if there's no option like this, but just a bit disappointed that earlier MY's were swappable and the kouki's are not.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 01-09-2021, 12:49 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
No they haven’t made anything like it. I was in the same boat and settled for yellow Lamin-X film.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
spike021 (01-09-2021)
Old 01-09-2021, 01:37 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
Can't just desolder/resolder new led's in and get much of the same beam pattern. Would take a re-engineering of the circuit board to do correctly. Likely $600ish minimum depending on a number of factors.
Laminex film is really the fastest/cheapest option
opening 2017 brz foglight assembly Breadman Cosmetic Modification (Interior/Exterior/Lighting) 20 10-22-2018 10:02 PM
2017 Yellow Series BRZ FTW Member's Car Journals 13 10-28-2017 06:50 AM
2017 Series Yellow Azzudien BRZ First-Gen (2012+) — General Topics 1 10-11-2016 07:55 PM
2017 BRZ SERIES.YELLOW VIP BRZ BRZ First-Gen (2012+) — General Topics 27 07-23-2016 01:35 PM
SAFE?:running nokya yellow bulbs in factory foglight housing jbsali Cosmetic Modification (Interior/Exterior/Lighting) 12 07-13-2014 11:42 AM
