Drives: brz
2017 brz Fog light bulb change possible???
I want to change my OEM LED foglights to a yellow bulb but I'm not sure how to remove the OEM bulb. Would I need to buy a whole new casing?
#2 |
No, its easy. Lift front of car- use jack stands. remove plastic clips for plastic guards under the car. You will see back of casing. I forgot how it opens, but I googled it and it was easy. Maybe 30 min to do both. A little longer if you are not an experienced wrench. I went yellow LED as well - they look pretty good. Not as good as yellow film, but then the glass is yellow all the time.
My bad, totally missed 2017. Mine is a 2016. So much for reading. Do the film, the yellow is the best. Only issue is its yellow all day as well. it looks best with black, it looks ok on my silver WRX. Last edited by Ernest72; 07-05-2017 at 10:07 PM. |
#3 |
Drives: 2013 Subaru BRZ
Can you post a link to the yellow leds?
#4 |
Drives: brz
![]() Here's a picture of the back. I'm not sure what I should do and I also bought the LEDs (2504/PSX24W) from Allah lighting from Amazon. https://www.amazon.com/dp/B011480LNM..._g4vxzb6W9269E The Amazon LEDs don't even look like they fit, or maybe I would have to shave some of the clips off... |
#5 |
almost positive the leds are soldered in (see: permanent)
#6 |
Drives: 2015 Series.Blue
2017's come with LED fog light assemblies. If you want yellow, use yellow film to get the look.
#7 |
Junior Pizza Joe
Drives: 2017 BRZ Limited Manual WRB
Is it really easy to install the film?
I've got a WRB and I like the blue with yellow look. Bill
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too. |
#8 | |
Drives: Neptune GR86
Also, there's no "bulbs". It's a single sealed unit.
#9 | |
I've grown tired of the film personally, but I keep it on because I like how it looks off and the film protects the fog lights. |
| How to change BRZ fog light bulb? | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 05-30-2020 06:31 PM |
| D.I.Y. - BRZ courtesy door light bulb change | joergasm | DIY (Do-It-Yourself) Guides | 24 | 09-13-2018 03:06 AM |
| Change HID bulb on BRZ | iLaw | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 11-05-2015 09:58 PM |
| Bulb Change - DRL stopped working | PNW FRS | Issues | Warranty | Recalls / TSB | 5 | 07-13-2015 12:54 AM |
| How many online forum members does it take to change a light bulb? | Hoahao | Off-Topic Lounge [WARNING: NO POLITICS] | 37 | 02-27-2015 10:42 PM |
